Old 16-05-2005, 12:16 AM   #1
bakes_eb
bakes_eb's Avatar
Default ef xr6 ecu into eb
hey guys would i be able to put a xr6 ef manaul ecu into my eb when i convert it into a manual and if so will there be any benefits i know they make it rev another 400rpm.
cheers scott
bakes_eb is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2005, 12:26 AM   #2
John_LS1
Posts: n/a
it wont work, the EF's run 100 pin ECU and use coil packs, the EB has a 60 pin ECU and runs a dizzy. you can use an EL XR6 manual one providing that your car has smartlock.
Old 16-05-2005, 12:33 AM   #3
bakes_eb
bakes_eb's Avatar
just double checked the ecu im looking at is out of an el not an ef
Old 16-05-2005, 12:37 AM   #4
John_LS1
Posts: n/a
should be OK then. does your EB have smartlock?
Old 16-05-2005, 12:45 AM   #5
bakes_eb
bakes_eb's Avatar
yeh mate i got smartlock wat benefits do you think it will have and how much would you pay for one?
Old 16-05-2005, 12:49 AM   #6
John_LS1
Posts: n/a
it changes the fuel mapping allowing you to run a lumpier cam with minimal loss of idle quality. will also let you run thermo's with out the need for a temp switch and also you will be able to run a BBM easier too.. i paid $200 for my manual ED XR6 one.
Old 16-05-2005, 12:54 AM   #7
bakes_eb
bakes_eb's Avatar
Im looking at $300 for the el one is the ed one simular to the el one?
Old 16-05-2005, 01:01 AM   #8
John_LS1
Posts: n/a
the ED one has less features than the EL one ie BBM stuff/thermo wiring...and id assume the mappings are slightly different again. both dont have the speed limiter.
Old 16-05-2005, 01:04 AM   #9
bakes_eb
bakes_eb's Avatar
do you think $300 would be good buying then?
Old 16-05-2005, 01:08 AM   #10
John_LS1
Posts: n/a
no idea, im not to sure what there worth, im sure someone would know.
Old 16-05-2005, 10:03 AM   #11
neb
hibernating
neb's Avatar
$300 sounds ok... el xr6 manual ecus are very hard to find and a fair few people are looking for them
neb is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2005, 11:05 AM   #12
NZ
NZ's Avatar
sox stuck one in hisxh ute which is fairly worked up he told me that although it didnt go any harder idle was improved and it was a bit more responsive to throttle.
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
NZ is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2005, 04:46 PM   #13
V8 Ghia
Formally ED I6
V8 Ghia's Avatar
I paid $250 for an EL manual xr6 ECU 2 weeks ago, but I would assume anywhere from $200 up to $400, depending on how quickly they want to sell it. I say go for it, they are very much in high demand.
Daily driver
98' AU 349ci Fairmont Ghia on LPG
Other
93' ED 5spd 4.0L NA Fairmont
13.75 @ 101mph
V8 Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2005, 12:00 AM   #14
bakes_eb
bakes_eb's Avatar
ok thanx guys now do i have to do any mods when i decide to hook the ecu up or do i hook it straight up.
thanx scott
Old 19-05-2005, 12:11 AM   #15
bakes_eb
bakes_eb's Avatar
