Old 08-09-2007, 11:50 AM   #1
imlach88
Default au sedan doors and ute doors??
are they the same door for each car???
im trying to gety hold of a passenger door for an au ute, can i use an au sedans passenger door??
imlach88 is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2007, 12:53 PM   #2
imlach88
the ute is an au xr8 if that makes a difference...
Old 08-09-2007, 02:21 PM   #3
T3man
T3man's Avatar
Yes, as long as it isn't the rear one.
Old 08-09-2007, 02:54 PM   #4
private9
www.TUFFCARPARTS.com
private9's Avatar
Yep, all pretty much the same!
private9 is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2007, 07:13 AM   #5
au2sw
Blown 5L coming
au2sw's Avatar
ivbe done heaps of research on this and have found the following.......
front doors are the same throughout
wagon and fairlane rear doors are the same
door cards are the same troughout.....ie long wheel base rear door cards will fit sedan rear doors
so to answer your question, yes, you can get AU sedan/wagon front door to fit the ute, everything will swap right over if you have power windows and the door you buy has wind up.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2007, 10:12 AM   #6
Dark Horse
_Oo===oO_
Dark Horse's Avatar
Good call Jeff!
The fronts would have to be the same or else it would've cost Ford a packet to make the AU.
COURAGE - ENDURANCE - MATESHIP - SACRIFICE
Dark Horse is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2007, 12:41 PM   #7
FTGAutosalvage
Commercial Sponsor
FTGAutosalvage's Avatar
series 1 & early series 2 doors are the same
late series 2 & series 3 doors are the same.
you can pick this by the bailey channel rubbers.
the early ones have a 1 piece rubber and the later ones a 3 piece rubber.
there are extra provisions on the late doors for the rubbers to clip on.
If you try and use the 1 piece rubber on a late door it wont sit correctly
FTGAutosalvage is offline   Reply With Quote Multi-Quote with this Post
