Old 28-10-2007, 09:47 PM   #1
TomXY
XY
TomXY's Avatar
Default Can you fit a pod filter on a carby?
hey,
just wondering if its possible to put a pod filter on a carby engine? how would adapt a pipe to the carb, would you need an adaptor plate or would you use a gas hat or something?
anyone got any ideas?
Tom
IGOTTABIGBLACKSHINEYCAR
TomXY is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2007, 09:59 PM   #2
nugget378
Weezland
nugget378's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to impart knowledge in the technical areas.
There is a ram type air setup available,
An enclosed "hat" goes over the carb,and from there two ducts run down to scoops positioned under the front bumper,this provides cool "ram air" to the carb.
But the filter is still in its normal place over the carb inside the "hat box"
A pod filter would be of no benefit whatsoever,and actually be a hindrance,you cant get much better flow than a 4" or 5"x14-16" K&N type carb filter element..
nugget378 is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2007, 10:13 PM   #3
TomXY
XY
TomXY's Avatar
thanks nugget, its for the 2v so you say the go is a carb filter element?
Old 29-10-2007, 12:27 PM   #4
nugget378
Weezland
nugget378's Avatar
Yes..
Looks good too...
Old 29-10-2007, 12:48 PM   #5
TomXY
XY
TomXY's Avatar
where did you get that from and how much did it cost?, is that a stromberg or holley?
Old 29-10-2007, 02:00 PM   #6
apolloxbgt
cross breeder
apolloxbgt's Avatar
Looks like a holley to me.
apolloxbgt is offline   Reply With Quote Multi-Quote with this Post
Old 29-10-2007, 03:38 PM   #7
TomXY
XY
TomXY's Avatar
yeah thought so.
i just need the easiest way to filter the air so it will pass rego.
Old 29-10-2007, 04:07 PM   #8
nugget378
Weezland
nugget378's Avatar
4 barrel holley 465.
It was on the car when I bought it..
These are pre adr27,so a filter like this is perfectly fine,and certainly the easiest way to do it,you will find something for the type of carb you run at rare spares or similar,even try ebay..
Old 29-10-2007, 06:42 PM   #9
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
If you want to run a pod filter, Supercheap sells a carbi adaptor, that fits over the carbi and give a 90 degree angle. It has a hole down the bend to screw into the carbi (where the normal bolt would run), etc, etc... worth a look if you want to run a pod filter/pipe setup...
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 29-10-2007, 07:32 PM   #10
irish2
Pod filters are useless on older motors and look crap. This is much better.
irish2 is offline   Reply With Quote Multi-Quote with this Post
Old 29-10-2007, 07:32 PM   #11
XCSEDAN
i'm baaaack....
XCSEDAN's Avatar
Tom, you see nugget's setup? thats what i was trying to tell you to get last night on MSN. it looks cool, and WORKS. the only problem is under bonnet temps, but they wont effect the performance of your XY i dont think ;)
XCSEDAN is offline   Reply With Quote Multi-Quote with this Post
Old 29-10-2007, 08:10 PM   #12
TEaaron
TEaaron's Avatar
Here is my motor before I put the holley on.
It's a 9" redline filter it made a massive difference and it made an even bigger difference when I got rid of the paper filter and put the K&N one on.
TE cortina 14.0 @ 101mph
E32 740iL Leather, sound system, rollin' on 19's
TEaaron is offline   Reply With Quote Multi-Quote with this Post
Old 29-10-2007, 08:37 PM   #13
TomXY
XY
TomXY's Avatar
the only problem is bonnet clearance, thats why i thought of a pod.
i tried one from supercheap and it hit the bonnet...
Old 29-10-2007, 08:41 PM   #14
nugget378
Weezland
nugget378's Avatar
The bend to make a pod will stick up just as high.
Use a drop base air cleaner,find out what other cars out there used this carb,LC torana's possibly etc,and you will find one that fits..
Old 29-10-2007, 09:12 PM   #15
TomXY
XY
TomXY's Avatar
thats why im asking to see if anyone knows of any such cars
Old 29-10-2007, 09:36 PM   #16
paule11
http://www.spectreperformance.com/#HOME
paule11 is offline   Reply With Quote Multi-Quote with this Post
Old 29-10-2007, 09:41 PM   #17
XCSEDAN
i'm baaaack....
XCSEDAN's Avatar
bonnet clearance... Tom isn't a double barrell stromberg standard on 250 2Vs?
Old 29-10-2007, 10:23 PM   #18
TomXY
XY
TomXY's Avatar
yeah but they have the drop base thin ones, and they are rare as and go for about $150
Old 30-10-2007, 07:58 AM   #19
Bosman
T Series Club Member No24
Bosman's Avatar
Mate i use an offset cleaner , not drop base , basically the carby hole is not central. Which means you turn filter to be predominantly towards the rear thus fixing clearance issue. They come in 10" and you can get KN filter if wanted. Initially used a Ram Filter but they are a crock. Cheers bos
1967 XR Falcon Mountain Blue Worked 250 2v , Kitted C4 , LSD , 10x14 Rear 9x14 front (LOW and FAT) had for 26 years....magnificent!
FTe Venom T3TE50 No229 5.6L Manual Don't drive one! Because like so many others , including ME , you will become TOTALLY addicted.
2016 Harley Davidson Softail Heritage customized.
Dead set gorgeous!
Bosman is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2007, 07:49 AM   #20
TomXY
XY
TomXY's Avatar
thanks bosman, what brand is the one you use? is their a website or anything?
