Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > ASL automedia
ASL automedia Specialising in the upgrade of BA/BF/Territory and FG audio and visual systems. We also repair all Ford (OEM) car stereos and produce OEM quality wiring harnesses. Website Link
Old 03-01-2008, 12:01 AM   #1
Kil4Collingwood
Kil4Collingwood's Avatar
Default Second hand CD stacker (BA)
Hi guys I have had a busted stacker in my '02 fairmont for some time so I recently got my hands on a working stacker unit but it is from a normal non climate ICC when the broken stacker is removed from the dual zone and replaced with the good one from the normal ICC the screen displays nothing not even "code" can this stacker be programmed to work in my ICC?
If so how much and does it get re-programmed with the unit removed or in-car?
The good stacker is from an '04 xr8 if it helps.
Kil4Collingwood is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2008, 07:51 AM   #2
FADI75
Sponsor
hi
the best thing to do is call us and book in your car to have a look at the cd module and to see if its compatible.
Sounds like you have the wrong cd module non compatible with the fairmont.
cheers
fadi75
FROM FALCON BA THROUGH FGX, TERRITORY SX THROUGH SZ - ICC UPGRADES, REPAIRS & INTEGRATION SPECIALISTS
AUTHORISED FORD REPAIR CENTRE
website: www.aslautomedia.com.au
email: info@aslautomedia.com
AUDIO INTERFACES, REVERSE CAMERAS, SATELLITE NAVIGATION & VIDEO INTEGRATION ON FACTORY COLOR SCREEN
FADI75 is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2008, 09:59 AM   #3
Kil4Collingwood
No need mate the stacker mechanism itself is totally different the one in the fairmont uses u-shaped plastic holders to guide the cds, whilst the new one is all metal plus the main boards are the same, but the smaller board that is screwed to the cover just above the mechanism itself the old (busted) one is tiny, the newer ones is about 4 times the size plus one of the ribbon connectors is different.
Thanks for your time anyway.
Old 03-01-2008, 10:04 AM   #4
FADI75
Sponsor
not sure what you mean, but no worries anytime.
cheers
fadi75
