Old 08-01-2008, 06:50 AM   #1
UKXR8
UKXR8's Avatar
Default Help with premium brake upgrade please!
Hi, I've got an AU2 XR8 sedan with standard brakes.
I've got hold of a set of premium brake calipers (grey stamped with the tickford wings) and a set of 329mm rotors from an AU2 XR6 VCT.
The problem is that when I went to trial fit them by fitting a few washers so that I could figure out how the thick the spacer was to the fit the caliper to the upright(aware that they need spacers due to the height of the rotor) the problem is is that the caliper sits too close to the centre of the rotor, almost as if the rotor needs to be about 325mm instead.
Is there something I'm missing, was the upright used on the standard car the same as on the T series/ XR AU2 premium brake cars?
Any help would be much appreciated.
Dave
UKXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2008, 06:53 AM   #2
JC
Miami Pilot
JC's Avatar
They should bolt straight up. Might be worth a PM to b2tf - pretty sure he has the premium brakes, so he may be able to give you better advice/pics etc.
Ford Performance Club ACT
Old 08-01-2008, 01:58 PM   #3
KOUPE76
OLD SKOOL BABY
KOUPE76's Avatar
They should have come with the rite brackets when you bought them, when I got mine they came with brackets and braided lines and was a straight swap.
XB Sedan - Trick Mansweto built 351 3V Alloy Headed Cleveland,Demon Carby ontop of CHI Hi Rise Manifold - 600HP
83 F100 XLT - 351 Cleveland C6 Auto wrapped in Black snake skin vinyl, daily tow rig.
1976 XB GS COUPE (waiting to start the rebuild)
KOUPE76 is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2008, 06:24 PM   #4
UKXR8
UKXR8's Avatar
Cheers for the replies.
Sounds like I'm missing a bracket somewhere... I've got the calipers, lines, the caliper carriers and the 329mm rotors.
What did the bracket look like, is it just a spacer with 2 holes to take the carrier bolts onto the upright or is it a bit more complicated than that?
Old 08-01-2008, 07:18 PM   #5
DJM83
Barra Turbo > V8
DJM83's Avatar
Premium brakes whether they come on XR's or anything else are the same. So wouldnt matter if it were Austin or not : that put the info. He didnt do his anyway im sure they came already on his ute
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+
-2022 Hyundai Tucson Highlander Diesel N Line
