Old 17-04-2005, 07:01 PM   #1
GTFalcon 351
Mmmm... Bikini Carwash...
GTFalcon 351's Avatar
Default Best way to reinforce firewall?
Just had a look at my mates 5 speed EA and it appears that there is a crack going 3/4 of the way around the area of the firewall where the clutch cable comes through, i hear this is quite a common problem and am wondering what the best method of fixing this is,
i have been thinking about pop riveting a 3mm thick plate over the area from the inside
'87 XF UTE 351C
'91 Peugeot 405 Mi16
'89 EA Falcon GL
GTFalcon 351 is offline   Reply With Quote Multi-Quote with this Post
Old 17-04-2005, 07:03 PM   #2
LUXO_8
windsor user
pop riveting the plate might work, however it will be super strong if you can weld the crack up then weld the plate in instead...
Old 17-04-2005, 08:56 PM   #3
Gunns
Gunns's Avatar
I grinded off the sleve that come through into the engine bay and riverted a 3mm stainless plate on and have had no problem thus far.
Gunns is offline   Reply With Quote Multi-Quote with this Post
Old 17-04-2005, 09:32 PM   #4
TUFED6
TUFED6's Avatar
I welded the crack up after it appeared, and it hasn't returned yet- even with the monster clutch I'm running these days.
I heard that there is a Ford part to repair the firewall when this problem occurs. Fiction?
- John
TUFED6 is offline   Reply With Quote Multi-Quote with this Post
Old 17-04-2005, 09:57 PM   #5
LUXO_8
windsor user
believe it or not, its fact tuffed lol
its basically a plate that you weld on the outside (engine bay side) of the firewall.....
Old 11-06-2005, 04:28 PM   #6
Qwikcorty
V8 Turbo Hoon
Qwikcorty's Avatar
- John
i need a new clutch soon, what would you recomend to hold about 200-250rwkw? my pressure plate is buggered atm, and as soon as it gets to about 3500 it will slip.
Qwikcorty is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2005, 01:13 AM   #7
TUFED6
TUFED6's Avatar
Xtreme make a few that would suit that sort of power. I think EASPRINT has a line on some good clutches too, and it sounds like one of the guys on this forum works for a clutch place. Someone on here can probably hook you up I reckon.
I'm running a tricked up Xtreme and its been awesome so far.
- John
