Old 25-01-2008, 11:43 PM   #1
brad`
The Monty
brad`'s Avatar
Default Oil Pressure problem
Hey recently... for some reason only at night.. my oil pressure guage will drop to zero and sound that stupid high pitched beep... but other times/days it wont do it. One of my mates said it might be a loose wire going to the sensor. 2 thinks wrong.. 1) no idea were the sensor is 2) never had to deal with sensors. I owned an 83 Mazda 626.. so im still new with all the electronics
brad` is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2008, 11:46 PM   #2
Mechan1k
Mechan1k's Avatar
Get all your earthing points checked ... it's a common issue.
Is your's a 6 or an 8???
The 6-cylnder oil pressure switch/sender is located on the passenger side of the engine block ... just in front of the engine mount (just behind the coilpack) ... it's a right pain to get to though.
Old 26-01-2008, 09:46 AM   #3
GK
Walking with God
GK's Avatar
It's a 27mm socket. A good mate lent me his as I didn't have one. I used a stack of extensions (mixed combination of length) and a uni joint to get the angle right.
You need to remove the airbox. Here's a few pics of when I did mine.
Angle of the extension bar
The Torque Wrench and Extension concoction!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 26-01-2008, 10:20 AM   #4
poolkeeper
Its Resonating!
poolkeeper's Avatar
Is this an easy fix or do you have to replace it??
poolkeeper is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2008, 05:23 PM   #5
GK
Walking with God
GK's Avatar
You could just remove the airbox and have a wiggle of the connecting wire. It may have worked a bit loose.
GK
Now gone!
On LPG
Old 28-01-2008, 10:19 AM   #6
XR8AU2121
XR8AU2121's Avatar
Hi Brad
My AU XR8's oil pressure gauge started going the same thing. Dropping to zero then flying up to the top of the gauge. Then go for days operating normally. When it started dropping to zero more often, and with the wiring looking ok, I decided to just replace the sensor to start with, which on the V8 is at the front of the block and can be just easily unscrewed. Screwed in a new sensor, $55 from Ford, no more problems, hasn't missed a beat since. Thats was about 9 months ago. So I would start with a new sensor and take it from there.
XR8AU2121 is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2008, 09:40 AM   #7
brad`
The Monty
brad`'s Avatar
hey thanks all, its a 6 'mechan1k'. so its under neither thats crap. the wiring looks ok like doesnt seem look any were. anything else i can do before i go out and purchase a new one ?
