24-06-2005, 12:29 AM | #1 | ||
B-Series Powered!
I want to do it myself to save some $$, do I need a buff? What brands do you recommend?
2003 BA Futura Pacemaker 4490's, 2.5" metal cat, 2.5" mandrel bent exhaust, hi-flow air filter, more to come! |
24-06-2005, 02:14 AM | #2 | |||
Personally, I just do it all by hand and use 2 cotton cloths to buff it off - usually old cotton T-shirts made into rags for example. Buff most of the wax off with 1 rag, then quickly again with the cleaner rag. Been doing this for 10 years and looks good. A place for technique tips is Karate Kid part 1
24-06-2005, 05:16 AM | #3 | ||
Yup I just use rags. Make sure you get the right sort of Cut+Polish as some are designed to be used with a buffing machine only.
24-06-2005, 09:46 AM | #4 | ||
RAGE Engineering
For one of the better car detailing guides, check this http://www.ls1.com.au/forum/showthread.php?t=40605
If it doesn't fit, use a BIGGER hammer |
24-06-2005, 10:32 AM | #5 | ||
The one and only
Hints:
clean car first. make sure 100% dry do not do in sun heat do one panel at a time. constantly flip rag to keep it clean. avoid plastics (it a pain to get off)
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
24-06-2005, 11:36 AM | #6 | |||
B-Series Powered!
Thx for the tips guys, appreciated..
25-06-2005, 06:34 AM | #7 | |||
Mr Polish
I'm crying out to you all, please read my car care tips article in technical resources T shirt & terry cloth rags create micro marring due to the cloth unable to get rid of the polish residue. It sits on the surface of the cloth and even when it looks clean you are wiping residue back over the paint. The old cars are more forgiving but if you have an AU or BA of any kind, go easy on it with microfibre towels and cloths, doesn't matter where you get them from. stay away from chinese made ones though
Detailology colour fx detail studio and R&D Lab SA's leader in auto detailing and paint treatments |
25-06-2005, 12:40 PM | #8 | |||
B-Series Powered!
26-06-2005, 03:07 PM | #9 | |||
Mr Polish
soft polish - light cut polish - 1500-1800 extra fine cut compound, 1200-1500 grit compound, 1000 grit compound use only as last resort Wash the car and with shampoo still on it, clay the paint well Use prepsol to remove any waxes or polymer sealants that are on there try the polishes with a hand foam pad, if doesn't work use a 1500-1800 grit compound. If you get the results you want, then remove swirls and finer scratches with a swirl mark remover (poorboys ssr 2 - 2.5 , menzerna PO85MF or FP II will do the job Use a finishing polish to get rid of the remaining marks Enhance with clearkote vanilla moose, red machine glaze and yellow moose (only clean and enhance, they do not remove paint) Seal with an acrylic, super polymer or polymer sealant (2 coats minimum), one to two coats of a pure carnuaba wax With every product use Side to side - top to bottom motions Clay the glass while your at it
26-06-2005, 05:01 PM | #10 | ||
Mr Polish
A couple helpful links for you
http://store.bettercarcare.com/paintpolish.html Go to bettercarcare.com and check out all the how to articles I don't agree with everything stated with those but it's very helpful
Detailology colour fx detail studio and R&D Lab SA's leader in auto detailing and paint treatments Last edited by SVR73; 26-06-2005 at 05:11 PM. |
