Old 04-05-2008, 07:43 AM   #1
Scams
Scams's Avatar
Default Drive line
Has anyone had the drive line bolts can loss on their focus?
I just had my wifes car fix it had a tick around the drivers side wheel it turns out it was the drive line bolt coming loss. It was a 05 focus if you hear a tick get it checked.
scams
Scams is offline   Reply With Quote Multi-Quote with this Post
Old 04-05-2008, 02:36 PM   #2
4dlvr
4dlvr
my car makes a squeaking sound, every time i reverse, or do sharp turns, most of the time it will happen as im letting of the clutch... could this be due to the same problem
96 EF FAIRMONT
Garrett gt40 turbo , iceman plenum, head ported, polished and balanced, wade turbo cam, wade double valve springs, bosch 023 fuel pump, 36lb injectors high flow cat, 4' dump and 2.5' redback exhaust.
215rwkw @7psi
4dlvr is offline   Reply With Quote Multi-Quote with this Post
Old 04-05-2008, 06:59 PM   #3
eXtremist
2007 Ford Focus Zetec
eXtremist's Avatar
Checked your fluid levels?
Last time I had a squeaking problem on a different car, it turned out to be the input shaft bearing.
It happened mainly when taking off, and turning.
eXtremist is offline   Reply With Quote Multi-Quote with this Post
