Old 29-06-2008, 11:30 AM   #1
JMO
JMO's Avatar
Default How to remove headlight...
I'm trying to get the headlight out (front right) to seal the edges to stop moisture getting in. How do i get it out without having to drop the front bar? all the bolts and wiring have been removed and it moves freely, but i can't seem to maneuver it out?
Is there a trick to it?
Cheers.
JMO is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2008, 11:51 AM   #2
LUXO_8
windsor user
there is also a bolt under the headlight.
you have to at least drop the bar on that side
Old 29-06-2008, 12:02 PM   #3
HLC
Audi S3
you dont have to drop the bar.
once all 4 bolts are out, looms undone including the indicator one, it takes a lot of wedging, angling, swearing, pulling, pushing and massaging to get it out. and then back in again.
Old 29-06-2008, 02:09 PM   #4
EvilChief
Boost Addict
if u tilt the top of the headlight forwards it tends to slide out reasoanbly easily
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build)
Ford BA XR6T Ute - daily driver
Ford FG XR6T Sedan - cruiser
do you see a general trend? I DO
Can't live with it, can't live without it!
EvilChief is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2008, 07:17 PM   #5
Mechan1k
Mechan1k's Avatar
As HLC and EvilChief mentioned ... a little bit of massaging and preserverance ... maybe a little bit of lost skin as well ... and it is manageable without dropping the front bar.
Old 29-06-2008, 08:13 PM   #6
JMO
JMO's Avatar
Thanks guys. I managed to get it out. I've sealed the bottom. Here's hoping it doesn't fog up again
