Old 18-08-2008, 01:38 PM   #31
sikford
THE Fairmont Ghia 75th
sikford's Avatar
Originally Posted by 99GHIA
Sorry I have no side on shots.
I just walked out to the car and took these as
it sits in the driveway. Keep in mind the fronts
always sit higher in Au's.
The pic Monty just posted is the
1st day suspension was done so still hasn't settled.
if thats SSL i might have to get em reset a bit lower, i thought SSL's sould be lower than that.will see when i go down to get the thing lowered what a mate thinks as he's the suspension guru.lol
Current Ride : AUII Fairmont Ghia : 75th Anniversary Limited Edition
Current Mods-HD Built Gearbox+(Mirror Polished, Modified Valve Body), 2500rpm Hi-Stall Convertor(TCE Custom Built), BIG Trans Cooler, Braided Lines/Speedflow Fittings, 2.5" Exhaust, Custom CAI, Detailed UnderCarriage, Custom SQ Stereo Install.
My Ride
My Build Thread
sikford is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2008, 02:36 PM   #32
BIGJB
BIGJB's Avatar
It still has heaps of clearance bloke. But keep in mind
if you go lower that photo is with only half a tank of fuel
and a empty boot. Full tank 2 adults 3 kids and a boot
full of crap it's a little different story.
BIGJB is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2008, 05:50 PM   #33
Fireblade
Wizard Member
Fireblade's Avatar
SSL is plenty low enough, it might not look like it but when you see how close the body is to the road you'll see. I'm putting a TS50 kit on mine soon and me thinks I will have to raise it up a notch to clear the usual driveways, speed humps etc etc. I've had reset SSL previously and destroyed an exhaust and bent the floor going into a driveway.
Frosty and FPR - Bathurst winners 2013
Fireblade is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2008, 06:33 PM   #34
Falcon SXR8
Falcon SXR8's Avatar
I just got a set of super lows for my XR8 and I noticed in the king spring book the the part number for super lows on a IRS au is the same as the part number for ultra lows on a live axle
Had
EB XR8
AU XR8 220 (awsome car )
AU Fairmont
BA MK2 XR6 Turbo
Now
XDUB
Falcon SXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2008, 06:39 PM   #35
sikford
sikford's Avatar
yeah thats very true i suppose, good point.i also have the weight of 2 fat 12" subs n 2 amps and a false floor to consider, maybe i might have to go supers.haha
My Ride
My Build Thread
Old 18-08-2008, 06:51 PM   #36
The Monty
Just slidin'
The Monty's Avatar
Thats extremely interesting.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 18-08-2008, 07:24 PM   #37
StealthAu
Interesting but completely wrong.
StealthAu is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2008, 06:25 PM   #38
blackers10
blackers10's Avatar
on the front they are the same.. on the rear im 99.999999% sure they are different.
Old 21-08-2008, 01:35 PM   #39
Falcon SXR8
Wink
Yes fronts are the same, but the rears are a different spring design beacuse of IRS and live axle. But as the fronts are the same number I would assume the rears are the same height if you know what I mean.
So from what I gather is that ultra low on a live axle AU is equal height to super low on an IRS AU.
Where I got the springs from the fella said his mate put superlows in his stock AU and it wasn't as low as my XR8 with superlows. And then we noticed the part numbers for the ultra low front springs on the live axle AU were the same as the part numbers for superlows on an XR8. The rears were different but there a different type of spring.
Anyway there my thoughts. I may be wrong
Had
EB XR8
AU Fairmont
BA MK2 XR6 Turbo
Now
XDUB
Old 21-08-2008, 05:50 PM   #40
StealthAu
Wrong, but only slightly, in the kings catalogue it lists au live axle, au irs, and au xr6/xr8 s/low irs. The xr listing shows ultra lows ans super lows and super lows as lows, because they were lowered from factory, the other two listings for the au share the same part numbers under fields of super low and ulta low, for the fronts.
Old 21-08-2008, 09:20 PM   #41
Fireblade
Wizard Member
Fireblade's Avatar
I have SSL that measures 335mm front and back, I want to raise my car to help clear speed humps, driveways etc. when I put my bodykit on, I trial fitted the XR50 front bar and it only just cleared my driveway by a couple of mm. So Can anybody who has SL or just low springs in their AU XR measure the height between guard and centre of the wheel for me so I have a rough idea of spring heights, this will be a good guide for people who want to lower their car too.
Old 21-08-2008, 09:25 PM   #42
Falcon SXR8
Thanks for clearing that up it was a few days ago I did it and I don't have a book to look at.
Had
EB XR8
AU Fairmont
BA MK2 XR6 Turbo
Now
XDUB
Old 21-08-2008, 09:27 PM   #43
StealthAu
No worries, the only reason they are shifted across a column is so when someone who owns an xr orders say lows, they receive something other then what they had from standard.
Old 21-08-2008, 10:29 PM   #44
superroo
You can't stop the signal
superroo's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Has done quite a few excellent write ups for au .com
Well here's a head F***k for you, my front SL springs give a measurement of 335mm.
Originally Posted by Matt Brown
I own a Dodge Viper and a minivan, and if I could only keep one of them, it would be the minivan
superroo is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2008, 11:52 PM   #45
MrXr6Tickford
AU Club Mod
MrXr6Tickford's Avatar
Would the combo of SL for the front and SSL for the rear work for my xr?
if so anyone have any shots of this?
-Tom
Interested in joining the Riverina Ford Owners Club?
Click Here
MrXr6Tickford is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2008, 12:28 AM   #46
HLC
Audi S3
this is king lows on shagged shocks.
Old 22-08-2008, 12:42 AM   #47
BLACKAUXR8
Young !@#$ Head
BLACKAUXR8's Avatar
the photo's of mine on aufalcon are SSL's on a series 3 XR8 with 20 inch wheels. I had the springs reset another 25 mm lower and it did scrape every where. Since the bigger wheels went on and the police told me to lift it up it now just has the SSL's and it doesnt scrape all that much. As long as your careful go SSL's AU's always look to high... Mine is going 25 mm lower again this weekend getting ready for the Kedron Ford show.
www.aufalcon.com.au/blackauxr8
AU3 220 XR8
CUSTOM PEARL PAINT
LOWERED THEN LOWERED EVEN MORE
ADVANTI 20's
K&N
PORTED MANIFOLDS
TWIN 2 1/2 into 3 inch PIPES
244rwhp
NOW WITH T5 5 SPEED
COBRA CLUTCH AND BILLET LIGHTENED FLYWHEEL
SUZUKI GSX-R 750
BLACK 2007 MODEL
CARBON FIBRE YOSHI PIPE
BLACKAUXR8 is offline   Reply With Quote Multi-Quote with this Post
