Old 06-09-2008, 02:49 PM   #61
Mullett
Badly Focused
Mullett's Avatar
So the XR5 springs sit about the same height as the stock Zetec springs, but have a firmer rate? Good info! As to what to do from here though, I'm not sure. I can't remember very clearly, but how thick is the top spacer which the front spring locates to? I remember the rear one being quite thick...
-RM.
07 LT CL, CAI, timing, XR5 springs, LS Zetec wheels
16.045...0.05 of a second! I wanted a 15sec pass!
93 GSR/Evo3...too much to mention, 12.2sec 1/4, FOR SALE!
*Maybe we don't try putting holes in things that sink, yeah?*
Mullett is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2008, 02:58 PM   #62
Lanyi
Lanyi's Avatar
Firmer rate it is. The xr5 springs are still shorter than the zetec ones (and the coil spring is thicker), so this means a similar ride height AFTER the springs settle.
From memory, the spacer was only about 10-15mm at the thicker end.
Lanyi is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2008, 03:18 PM   #63
TITO
Originally Posted by marg99
"Sports suspension" remains an option on LT models (CL,LX & zetec) but not TDCI, although the XR5 has its own sports suspension option.
The Zetec is fitted with sports suspension from the factory, any option your dealer is offering would be after market.
TITO is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2008, 01:05 PM   #64
want-a-XY
want-a-XY's Avatar
RJM89 did you install your xr5 springs this weekend? any news?
want-a-XY is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2008, 04:35 PM   #65
RJO89
EuroFordClub
RJO89's Avatar
Nah mate haven't gotten around to it. It might be a while before I end up doing it!!
'08 Black Ford Focus LT CL Hatch
Far from stock... --- SOLD :
Now riding a 2009 Kawasaki Ninja 250R :
RJO89 is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2008, 12:05 AM   #66
want-a-XY
want-a-XY's Avatar
i'm just guna buy these springs and get them fitted professionally. probably won't be a while either before i get them installed
Old 08-09-2008, 12:38 AM   #67
RJO89
EuroFordClub
RJO89's Avatar
I'll let you know if I end up putting mine in or not. If I decide not to do it you can buy the ones I've got if you want.
Old 08-09-2008, 01:15 AM   #68
Mullett
Badly Focused
Mullett's Avatar
Sounds like the consensus is that it's worth doing as far as lowering goes, but only if you haven't already got the Zetec suspention. As for the firmer rate, that's a personal question I'm very happy with it...but now I need better shocks On another note, just done the ignition advance, let's see how it goes
-RM.
