08-10-2008, 09:08 PM | #1 | ||
Formerly MR BAXR6t
Hey all
I just got my engine mount done and ever since, the gear knob, while ur accelerating hard and going over bumps the gear stick moves all over the place. Ive had both engine mounts now replaced in the last 6 months what else could it be? Also there is a clonk/banging noise when hitting bumps semi hard. Is there and gearbox mounts or sumthin like that could cause this?? All sugestions appreciated Cheers Frank
Current car 94 ED Fairmont 5L in Burgundy Fords ive owned- 2010 FG XR6 5 speed auto in Mystic 81 XD S-Pac 302c 4sp manual 78 Yellow TE Cortina Wagon 4.1L 92 Green EB Fairmont GT replica 01 Black AU XR8 II Manual 04 Rapid BAII XR6T 220rwkw 04 Mandarin BA XR6T 247rwkw 07 BF II XR6T 385rwkw 1980 ZJ Fairlane 302c |
08-10-2008, 09:10 PM | #2 | |||
Back to Le Frenchy
There is a gearbox mount, back of the box at the crossmember.
08-10-2008, 09:13 PM | #3 | |||
Formerly MR BAXR6t
08-10-2008, 09:29 PM | #4 | ||
Back to N/A land
Yup absolutely
09-10-2008, 04:52 AM | #5 | ||
also lowered cars do this, mine does it
09-10-2008, 06:41 AM | #6 | ||
Mine had a rubber bush on the mount that needed replacing, and fixed it straight away.
09-10-2008, 06:55 AM | #7 | ||
Just slidin'
All Au's do it as far as I know. There has to be give as if you hit a big bump at 100 K's, and nothing in the gearbox moved (ie, your gear stick), something would break.
MD Mondeo - For the family
09-10-2008, 08:48 AM | #8 | |||
gone fishing
Cheers Whiskers |
09-10-2008, 10:28 AM | #9 | ||
all live axle cars will do it, but theoretically irs cars shouldn't as the actual diff housing shouldn't move with the rear suspension. the centre is fixed and the arms move, thus the driveshaft shouldn't move when the wheels do...unlike live axle, which does
09-10-2008, 11:07 AM | #10 | ||
Formerly MR BAXR6t
Mine neva used to do it as much as it does now. I understand a little movement can happen, but its wobbling a bit more than usual.
It happens at any speed not just at fast speeds. It more the clunk im wondering about too. cheers frank
09-10-2008, 12:14 PM | #11 | ||
Red is nice Mark.
Check gearbox mount. They mave have undone it or loosened it when changing the engine mount. The geatrbox mount may have broken with the extra transfer of force from the new engine mount. This has happened to me in a V8 NL.
Twin T3's TE 50 #72 Blueprint & TS 50 #105 Blueprint : |
09-10-2008, 08:51 PM | #12 | |||
Formerly MR BAXR6t
Cheers frank
10-10-2008, 11:02 PM | #13 | ||
Formerly MR BAXR6t
I had a quick look today, still looks like the left extractor is still leaning on the crossmember! Which could be the knockin noise over bumps.
Has anyone else had these problems when putting extractors on? I dont know how it could still be hitting with the new mount? Any ideas?? Cheers Frank
10-10-2008, 11:11 PM | #14 | ||
Did you put everything back where its supposed to go properly?
Best to check everything again. |
10-10-2008, 11:21 PM | #15 | |||
Formerly MR BAXR6t
10-10-2008, 11:34 PM | #16 | ||
If the extractor is leaning on the crossmember after a mechanic fitted it i would be rushing back there and getting him to fix that straight away.
11-10-2008, 07:51 AM | #17 | ||
The extractors on my lowered AU2 used to hit the frame somewhere. Exhaust place ended up heating them a bit, and reshaping them to clear (read that as belting with a hammer). They also ground down the head of one bolt on the drivers side for clearance, but left enough to get a spanner on still.
