Old 20-07-2005, 08:46 PM   #1
Clarke AV
OzECruisers Treasurer
Clarke AV's Avatar
Default Timing on a V8
I know you have to disable the computer with a clip lead from the connector next to the fuse box. I am stumped, I'm shorting out the top left pin to ground. Nothing's happening, I've tried all the rest, where is the diagnostic input pin for setting the timing?
Clarke AV is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2005, 08:59 PM   #2
EDXR8
EDXR8's Avatar
You have got the correct pin, short the top left hand pin to earth or to the bottom left pin, start the engine and in a few seconds the engine should rev up to and remain at 1500-2000rpm (can't remember exactly) for a while, thats when you set the timing.
EDXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2005, 03:54 PM   #3
4.9 EF Futura
Official AFF conservative
4.9 EF Futura's Avatar
Would pay to check this... your comments grant... but the mustang guys disconnect the TFI loom and apparantley this locks the engine in at 10 degrees BTDC...
i.e. the software base timing is 30* BTDC but mechanical timing is 10 * BTDC....
A cup half empty... but full of euphoria.
4.9 EF Futura is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2005, 03:56 PM   #4
!Gn|T|0n
!Gn|T|0n's Avatar
This is how I do it.
Still saluting the Ford flag.
!Gn|T|0n is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2005, 05:52 PM   #5
EDXR8
EDXR8's Avatar
Yeah I know the mustang guys remove the TFI plug but have never tried that myself. Using the diagnostic port is easy and is what is specified in the manual.
