Old 04-02-2009, 02:07 PM   #1
jayjays
Default Focus TDCi exhaust smoke
Hi all, am new to this web site, have found some great information. I have owned my 2007 TDCi for 5 months now, bought as a demo and now has 13000 km on the clock. Thinking of freeing up the intake and exhaust system at some stage.
Anyway, was just wondering wheather anybody with a diesel focus has noticed a small amount of smoke from the exhaust at around 3000 rpm. I only notice this in following car headlights at night time. Doesnt seem like a great deal though. Have been on to 2 seperate dealers and they say this is normal. Im not an expert on modern diesel engines but I would have thought that with all of the restrictive pollution gear on these cars there wouldnt be any smoke. Any comments would be greatly appreciated. Thanks all
jayjays is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2009, 05:40 PM   #2
AnthonyTDCi
Focus TDCi
AnthonyTDCi's Avatar
yes this is completely normal.
you will actually find it happens alot between 1800-2200 when the car hits boost.
as for pollution....there might be alot of smoke coming out...but its the carbon emission count that is alot lower than petrol engines. (someone correct me if im wrong)
AnthonyTDCi is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2009, 06:08 PM   #3
819_FLY
819_FLY's Avatar
Yeah would be extra fuel passing through the engine. The particulate matter is the black stuff you see (like a soot) and diesel burns cleaner than petrol. Having a turbo is good for that especially if you get under the pedal a bit. I used to own an R32 GTR and when that thing got onto boost was a massive cloud of fuel coming out from behind... nice clean BMW.... Not any more hahahaha!!!
If it is white, then usually its unburnt fuel, if its blue then its burning oil, when you are on boost it most likely is a oil leak on the inlet side of the turbo, if you let off and smoke billows out then chances are it could be a thrust seal in the turbo. Black stuff is the normal for diesels, just not as much as a Prime mover or Locomotive.
I drive my American Owned, German Inspired, South African Built, Australian Bought, European Styled, English Powered car. I might have missed something somewhere... 08' LT Ford Focus CL
Check out 819FLY!!
819_FLY is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2009, 07:59 PM   #4
orsest170
WRC Fanatic
orsest170's Avatar
You are right, but there's more to the story......Diesel actually emits more CO2 per litre of fuel burned than petrol (2.7kg vs 2.3kg CO2/L), but because a diesel car is is so much more efficient than the equivalent petrol (typically using about 25% less fuel), the CO2 emissions still work out in favour of the diesel.
Most of the new generation diesels are coming out with particulate filters, and I expect the next gen Ford diesels offered in Australia (already avail in Europe) to follow suit. They work extremely well (although can be prone to clogging with prolonged city driving), and eliminate virtually all the particulate smoke.
Panther Black XR5T
Pro Alloy Intercooler| Angel Eye Headlights (black)| Eibach Prokit Springs| K&N Gen II 57i CAI|
Dreamscience| InPro Black LED Tail lights| Black RS GT wheels| 14.007 @ 100.55 mph
orsest170 is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2009, 10:40 PM   #5
Mullett
Badly Focused
Mullett's Avatar
Quick note: white smoke is oil, black smoke is unburnt fuel, blue smoke is partly unburnt fuel, or fuel and oil.
-RM.
07 LT CL, CAI, timing, XR5 springs, LS Zetec wheels
16.045...0.05 of a second! I wanted a 15sec pass!
93 GSR/Evo3...too much to mention, 12.2sec 1/4, FOR SALE!
*Maybe we don't try putting holes in things that sink, yeah?*
Mullett is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2009, 11:09 AM   #6
BlackLS
yum
-RM.
Or your running 2 stroke.
2005 LS Focus LX
Nov05 | Manual | Black Sapphire
250,000kms.
BlackLS is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2009, 09:21 PM   #7
AnthonyTDCi
Focus TDCi
thanks man!
i new they were better for the environment one way or another lol.
i had an old magna which blew out blue smoke from crappy valve stem seals....i thought white smoke was a water leak in the engine??
Old 05-02-2009, 10:12 PM   #8
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
white smoke =/= steam
Old 05-02-2009, 11:54 PM   #9
Mullett
Badly Focused
Mullett's Avatar
As well, I forgot about the water in the engine/exhaust white smoke...it's easy to tell the difference though, the steam disperses very quickly once it hits the air, white oil smoke holds its shape a lot better...
-RM.
Old 06-02-2009, 03:21 AM   #10
jayjays
Thank you to all that replied. Very helpfull. Just another question, is there a requirement to "idle down" or cool down the turbo after driving on modern stock standard (not for long with mine) cars? Cheers
Old 06-02-2009, 05:33 PM   #11
Turbodiesel
Torquer
Turbodiesel's Avatar
Nope, just make sure the engine is at idle revs when you turn it off.
Turbodiesel is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2009, 11:51 AM   #12
jayjays
Cheers.
Old 07-02-2009, 09:28 PM   #13
Mullett
Badly Focused
Mullett's Avatar
Modern, watercooled turbos have almost eliminated the need for this, the main problem was caused by oil 'caking' inside a hot housing, which slowly built up and prevented the shaft from being properly lubricated (can you imagine anything worse :P) Water cooling has ensured that the housing shouldn't reach temperatures which can cake the oil into the housing, so unless the car has been running very hard before shutdown (like towing a trailer up a big-*** hill) it's not a problem at all. The common misconception is that the idle down time is to bring the turbine speed back down as low as possible to prevent it from spinning without oil, but with the engine shut off the turbine stops VERY quickly due to the drag of the impeller in the air.
-RM.
Old 10-03-2009, 08:47 PM   #14
elgreko
elgreko's Avatar
Hi All
New to thread just bought a tdci focus and I love it! But I discovered a lot of oil around the pipe that comes out of the inter cooler, into the inlet manifold. I pulled off the pipe and discovered some oil inside, is this normal?? the car has 15000 kms on it.
elgreko is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2009, 11:20 PM   #15
819_FLY
819_FLY's Avatar
I would assume not. Usually the induction side after the turbo is completely dry and if you are getting oil passing through the intercooler then something would be up, have you noticed any clouds of smoke from your exhaust, if its burning oil then you will definately notice one.
Check out 819FLY!!
Old 11-03-2009, 12:58 AM   #16
zetec
Zoom Zoom
zetec's Avatar
Black Smoke
White Smoke
2012 Mazda3 MPS
Old 11-03-2009, 06:23 PM   #17
elgreko
elgreko's Avatar
smokes only if I floor it, about 2000 RPM, but was told that was normal!! By ford Dealer.
Old 11-03-2009, 06:37 PM   #18
elgreko
elgreko's Avatar
Just noticed that there is no instant fuel consumption display on my 08 focus TDCI My brother in-law has a 07 focus TDCI and his has instant fuel consumption display?????
Old 11-03-2009, 09:58 PM   #19
Loris
Focus & Territory TDCi
hmm, i have the instant fuel display on my 08.. somethings up with yours not being there
Loris is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2009, 07:08 PM   #20
Turbodiesel
Torquer
Isn't there only an average fuel usage display? You can sort of make it instant if you reset it while driving.
Old 12-03-2009, 09:34 PM   #21
marg99
my MY 08 TDCI has the instant fuel usage directly after the "average fuel" usage on the display settings. Have you gone through all the display settings?
Old 12-03-2009, 09:59 PM   #22
Loris
nope, i have both
Old 13-03-2009, 11:52 AM   #23
elgreko
elgreko's Avatar
Mine definately dose not have it. Went to the ford Dealer in Epping in Melb he said and I quote "Ford do funny things sometimes from month to month, some models have them and some dont"???? I think that bull#!@@!! I told him to get confermation and to get back to me, I bet you he dosnt!!
Old 13-03-2009, 04:32 PM   #24
sumpPUMP
SUMPA's sedan
sumpPUMP's Avatar
my zetec doesnt have it either, but my mum's does...
must be a setting somewhere. havent really chased it up yet.
'07 sapphire black manual LT focus zetec sedan
6.5" alpine dvd player - alpine splits - response amp - alpine 12" sub - lovell's supalow springs - LV XR5 Focus wheels - Kumho KU31's - black leather - tint
sumpPUMP is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2009, 10:12 AM   #25
elgreko
elgreko's Avatar
Default Instant Fuel usage
Ford dealer just called, told me my model doesn't have it my build date is 3/08 anyone with a similar build date have it??
Old 19-03-2009, 12:57 PM   #26
Turbodiesel
Torquer
Well I reckon that sucks balls, it should at least be consistent between same model cars.
Good for you guys who have it though, mine was one of the first TDCis off the boat.
Old 19-03-2009, 03:20 PM   #27
sumpPUMP
SUMPA's sedan
sumpPUMP's Avatar
mine is april 2007 build (zetec) and i havent got it but my mums is the same build in tdci and has it, i seriously dont get why they would chop and change between the models and builds.
