Old 20-03-2009, 11:08 PM   #1
rand0mn00b
Default triggering ESP/ABS
Hi Guys,
First timer here love the forum that's happening and hope to be contributing (and asking) a fair bit over the course of time.
Picked up an August 2007 LT Zetec Sedan 2 weeks ago privately. Was an economic write off from hail damage so no warranty I believe. It has just ticked over 23,000km.
Have been taking it easy familiarising myself with it. Occasionally I drive a little more 'aggressively' and the handling on this thing is great.
Over the last 5 days I've progressively pushed the car harder and may have reached its limits before ESP/ABS to kick in. This is from taking corners/roundabouts a little too quickly where the road is not even so momentarily a tyre becomes airborne and the rear slides out.
It is at this point that I (and probably ESP) back off on the throttle and the car moves in the direction the steering is pointing again.
However the ESP and ABS lights stay illuminated and the display says "ESP System Fault" even after the moment has passed.
I fix this by pulling over and turning off the engine. When I restart the engine the ESP and ABS warning lights stay on until I roll about 50 metres then they disappear.
Has anyone else triggered ESP? What happens for you?
Does this behaviour seem normal otherwise? Should I get it checked out?
Thanks in advance!
rand0mn00b is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2009, 10:14 AM   #2
pertuan
Focus on my Focus
To my knowledge, the light should not stay on at all. It will be on while the system is working but should extinguish after that.
I'd get it checked.
Now: 2006 Ford Focus LX Manual in Satin White
Wife: 2013 Kuga Titanium in Frozen White
Then: 1990 Ford Laser - Assasinated by a 76 year old man who failed to give way.
Now normally when we have these races, Jeremy goes in the car and says "Powerrr" alot.... - James speaking about Jeremy (Top Gear S7 E05)
American parts... Russian parts... ALL MADE IN TAIWAN! - Russian guy in Armegeddon
pertuan is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2009, 11:01 AM   #3
marg99
my ESP comes on if you hit uneven road surface when cornering, but the light is only on when the system is working. The most likely suspect is a faulty sensor however it should be checked as the system may not be working while the fault shows.
Old 21-03-2009, 05:38 PM   #4
rand0mn00b
ok thanks guys. i guess a ford dealer is best for this kinda thing?
any particular dealers I should stay away from? or that I should go to first?
thanks!
edit: i'm in sydney
Old 21-03-2009, 06:15 PM   #5
Tj-zetec
Knows nothing. Apparently
Tj-zetec's Avatar
Not sure who're the ones to miss in sydney but i've heard good things about the service dept at Power Ford in Castle Hill.
2008 Electric Orange LV XR5. With dreamscience strategem SCT, K&N 57i Gen2 cold air intake for more fun and demonic vaccum cleaner noise!!
1975 Mitsubishi/Chrysler GC Galant 2-door Hardtop. 4G63 DOHC heart transplant nearly complete!
Check out the build over here
Tj-zetec is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2009, 01:56 AM   #6
BlackLS
yum
Sounds like an dud ABS sensor is to blame.
2005 LS Focus LX
250,000kms.
Old 22-03-2009, 04:22 PM   #7
Turbodiesel
Torquer
Turbodiesel's Avatar
That's handy to know, I have to turn mine off before I go around a certain corner on the way to work because the corner is bumpy and it activates.. I hate the sound it makes...
Yep the orange light should flash for a few seconds and then stop if the ESP is activated.
Turbodiesel is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2009, 10:52 AM   #8
Forest Bear
Does anyone know if the car's management system records the number of times ABS/ESP is triggered when plugged in at ford for servicing?
Forest Bear is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2009, 11:22 PM   #9
Mullett
Badly Focused
Mullett's Avatar
it sounds to me like one (or more) wheel sensors are losing sync, after 50m of straight driving it sounds like they work it out among themselves and get on with it. It's definitely a systems fault.
I don't know much about it, but I wouldn't have thought that being an economic write-off would have voided the warranty...
How much did it cost you to repair the damage?
-RM.
07 LT CL, CAI, timing, XR5 springs, LS Zetec wheels
16.045...0.05 of a second! I wanted a 15sec pass!
93 GSR/Evo3...too much to mention, 12.2sec 1/4, FOR SALE!
*Maybe we don't try putting holes in things that sink, yeah?*
Mullett is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2009, 12:47 AM   #10
rand0mn00b
thanks guys
I'm not sure either, but it said that in the manual if it's a 'write off' (their exact wording) then it's no longer covered under warranty. I emailed Ford Australia about it and was told to visit my nearest dealer so I might just do that.
Not sure, I bought it after it was repaired.
Old 24-04-2009, 10:18 AM   #11
rand0mn00b
Heh well I've had ESP go off legitimately a couple of times and yes it only blinks for a few seconds and then off. So at least it's working when the ESP system error light isn't on.
It now happens even if I hold the steering slightly to the right for prolonged periods of time when taking a large bend.
It's worst when I'm quickly braking, pressing clutch and turning right around a sharp bend I will also hear a single clunk, but it sounds like some metal is scraping against the bottom of my car. it stops once the ESP faulty lights come on
And I'm also hearing what sounds like some springy noises. The most similar noise I can think of is when you lean back on an office chair and you can hear the spring compressing... it sounds like that. This continues even after the fault light comes in
So it sounds like driveshaft/CV joint/maybe ABS or ESP sensor related - might be costly without warranty =(
Old 24-04-2009, 11:43 AM   #12
BlackLS
yum
Lucky you have warranty due to hail damage only affecting the cosmetics of the car and not the mechanicals.
2005 LS Focus LX
250,000kms.
Old 24-04-2009, 11:51 AM   #13
rand0mn00b
I checked with several ford dealers, everyone who's replied back has said it's no longer covered by warranty even if it was just hail damage :(
Old 24-04-2009, 12:18 PM   #14
marg99
if you are getting front end noise at about the time the ESP triggers I would suggest one of the front brake sensors and the front hub assembly are not properly aligned causing the sensor to misread or loose a signal. My falcon had that issue when it lost a front bearing in the hub assembly and it was touching the sensor arm.
Old 24-04-2009, 01:01 PM   #15
BlackLS
yum
Mr Random, you got a PM.
2005 LS Focus LX
250,000kms.
Old 20-05-2009, 12:12 AM   #16
rand0mn00b
I'm very pleased with the team at the service department of thomson ford in parramatta. Service, response time and communication has been excellent esp by Lee, the assistant service manager
so far they've:
1. validated the warranty status of my car with ford australia (excluding the body and any damage deemed to have been caused in the process of its repair, which is fair enough)
2. took the car in to have it looked at, turns out the problem was a 'tone wheel failure'. parts for that and the drive shaft are incoming - all covered by warranty
tracked down and diagnosed a couple of other issues i mentioned while i was there that will now also be repaired under warranty
when all the parts arrive she'll be going back in to have them fitted
let's hope the rest of the journey goes as smooth as it has thus far
Old 20-05-2009, 02:12 PM   #17
BlackLS
yum
Awesome to hear!!!
2005 LS Focus LX
250,000kms.
Old 20-05-2009, 11:23 PM   #18
AnthonyTDCi
Focus TDCi
AnthonyTDCi's Avatar
hmm...i just made a thread on what i think might be the exact same problem....
AnthonyTDCi is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2009, 11:50 PM   #19
rand0mn00b
just a few points of interest for the information of anyone else who might stumble across this
re: warranty, it's not stated in the user manual, but in the log book it states that even if it's been written off but you can prove that it's a fault in manufacturing then you are still entitled to make a claim
I think most dealers can't be bothered checking with Ford, Thomson Ford impressed me in that regard (even though I didn't buy my car from them)! A couple of dealers checked too, but weren't as attentive or at least appeared to be concerned in a good outcome.
re: tone wheel, apparently it's a magnetic wheel that tracks how a wheel is moving and feeds that data back to the ABS/ESP/ECU. in my case the front left one was damaged and so yeah, I guess it was losing sync with the rest of the system. I don't know if it's the same thing as an ABS sensor but its function seems similar.
Old 26-05-2009, 02:24 AM   #20
rand0mn00b
just collected the car from Thomson Ford today. All appears to be well, for now... :p
