Old 24-07-2009, 01:04 PM   #91
GK
Walking with God
GK's Avatar
Thumbs up
Originally Posted by RG
Oil pressure switch screws into the block just above and toward the front of where the oil filter sits. To give you an idea of exactly where the hose connections for the cooler onto the filter adaptor sit right in front of it blocking any easy access.
Indeed. Very good suggestion.
IIRC, a few V8 owners have had an issue with the sender/switch cracking. It may have done so with the extra heat.
Well worth a check.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 24-07-2009, 01:21 PM   #92
InfernoSR
Sales Representative
InfernoSR's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For research and posted write up on cooling system care and repair in AU.COM and offering help where possible
Originally Posted by james22
Yeah mate... Been keeping it in mind. Been buttering my mrs up for the last 2 weeks lol : Maybe she'll let me spend some $$$
Well dont get me to help you do that... she'd beat us both up!... ing_sm
InfernoSR is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2009, 01:21 PM   #93
james22
With da Warlords
james22's Avatar
Of course lol. ford wouldn't make it easy to access lol. That would mean less labour = less money for them to fix ing_sm.
I think I read in your build thread you only replaced yours recently... Any suggestions for how to get to it a bit easier next time? Maybe disconnect oil cooler lines or something?
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear.
For Sale: Parachute. Only used once, never opened, small stain.
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
XR50T Ute - 300rwkw (give or take depending on the day)
james22 is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2009, 01:24 PM   #94
james22
With da Warlords
james22's Avatar
Yeah mate rofl. Scary woman :gren:
Windsor Warlords
AU III XR-8220
Old 24-07-2009, 01:36 PM   #95
InfernoSR
InfernoSR's Avatar
No she isnt... she is a very lovely and caring young lady...
Old 24-07-2009, 01:51 PM   #96
RG
Back to Le Frenchy
RG's Avatar
Remove the drivebelt and have small hands.
Old 24-07-2009, 02:30 PM   #97
james22
With da Warlords
james22's Avatar
Easy done on both counts lol.
Windsor Warlords
AU III XR-8220
Old 24-07-2009, 02:32 PM   #98
RG
Back to Le Frenchy
RG's Avatar
No it isn't, not even with the required small hands.
The OEM one is bigger than the replacement ones and you can't get any decent movement in there.
Old 25-07-2009, 11:32 AM   #99
james22
With da Warlords
james22's Avatar
Ok so its ALIVE!!!! - finshed re-assembling it about 9.00 last night.
Placed a bit of board under the car so I could accurately see how much oil it lost.
It started and run perfectly, under revs there was no obvious sign of it pushing oil out so was happy with that. Used no water and no signs of mixing after running for about an hour.
As for the oil leak, the board today after 15 hours or so of sitting there, only has approximately a patch the size of a 50cent coin. So the leak is by no means severe.
I'm going to take it for a drive up a Mountain here that is steeper than Mt panorama. Load test it, 3rd gear at about 40kph will certainly do that. If it doesnt show any signs of using water / oil - or mixing the two then, I may be able say that I have gotten away with this :-)
Now to go degrease the area...
Windsor Warlords
AU III XR-8220
Old 25-07-2009, 11:57 AM   #100
InfernoSR
InfernoSR's Avatar
Great news mate!
Old 25-07-2009, 02:13 PM   #101
james22
With da Warlords
james22's Avatar
Thanks mate ^^^
Hahaha so I found my leak... The oil filter was loose lol. Tightened it up a whole turn and a half. I suspect that tommorow there will be no more leak :-) Hows about that for easy
Windsor Warlords
AU III XR-8220
Old 25-07-2009, 02:57 PM   #102
xr8ute
Back on the road
xr8ute's Avatar
Glad it seems to be running OK.
If you havent already done it (since it overheated), then change the engine oil for some fresh oil before you take it for any sort of serious drive.
AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute
5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor.
Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash.
xr8ute is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2009, 05:35 PM   #103
InfernoSR
InfernoSR's Avatar
Yeah I'm waitinig for all the "I told you so's lol"
Told ya so!... :
Old 25-07-2009, 06:49 PM   #104
james22
With da Warlords
james22's Avatar
Oops, bit late lol. Already tested it as such....
Car went well, performed fine. I warmed it up on the way, then started labouring the car progressively up the mountain. Got to the top, checked all the fluids, and then drove back down, (compression braking) most of the way.
End result;
No apparent problems with the engine, no signs of mixing fluids, and no leaks.
So I think I may have got away with it.
Only thing it has cost me is, A bloody fuse, a few gaskets and coolant.
And while I was at all this, I had a chance to clean up the runners on my upper and especially lower manifold. No #2 and #5 seemed preety average.
So all in all, I suppose I should thank my lucky stars. And just wait and see if any problems arise in the future.
Windsor Warlords
AU III XR-8220
Old 25-07-2009, 06:58 PM   #105
james22
With da Warlords
james22's Avatar
I should add that I warmed the car up thoroughly before doing this, Never took it over 4000rpm and only loaded/laboured the enigne incrementally. Also had a 'chase' vehicle to monitor any fluid loss or smoke etc.
Windsor Warlords
AU III XR-8220
Old 26-07-2009, 02:01 AM   #106
JC
JC's Avatar
Good result - I well and truly cooked my old Windsor about 15 months or so ago, but that was due to the mechanic leaving the radiator cap off, so they paid for maching heads etc. At least yours has only cost a few bob and a few weeks in time.
Now.....anyone know how to remove an allen key bolt if the allen key snapped off and is stuck in the bolt? I'm thinking multi grips! And why aren't hardware stores open when you need them (like now?).
Ford Performance Club ACT
Old 26-07-2009, 03:59 AM   #107
CFOUR
The Destroyer
CFOUR's Avatar
grind a flat head screwdriver drive into the top of the allen key
Toy- Blown XR8 Ute. Black on black
"Front-drive cars are for children"
CFOUR is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2009, 09:21 AM   #108
JC
JC's Avatar
Thought of that, but no room to get a grinder near the bolt.
Old 26-07-2009, 09:45 AM   #109
GK
Walking with God
GK's Avatar
She's watching isn't she?
GK
Now gone!
On LPG
Old 26-07-2009, 09:49 AM   #110
GK
Walking with God
GK's Avatar
I thought you were working on my cluster? LOL!
GK
Now gone!
On LPG
Old 26-07-2009, 09:58 AM   #111
GK
Walking with God
GK's Avatar
Thumbs up
Good result all in all. Thankfully you've avoided the very worst.
GK
Now gone!
On LPG
Old 26-07-2009, 11:33 AM   #112
InfernoSR
InfernoSR's Avatar
GK
She probably was... :
Old 26-07-2009, 01:55 PM   #113
GK
Walking with God
GK's Avatar
LOL!
GK
Now gone!
On LPG
Old 27-07-2009, 03:08 PM   #114
CFOUR
The Destroyer
CFOUR's Avatar
Use a dremel
