Old 06-08-2009, 11:36 PM   #1
zaczac
Default Qld engine conversion laws
I had a look on the QT website, but can anyone confirm or point me in direction of details on engine conversions?
what I am after is what is the max cubic capacity you can go to depending on a vehicles weight, or is it based on other factors?
thanks in advance
jas
zaczac is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2009, 03:27 AM   #2
veqlargh
Originally Posted by http://www.infrastructure.gov.au/roads/vehicle_regulation/bulletin/pdf/NCOP3_Section_LA_Engines_3Feb2006.pdf
1. Fitting of a replacement engine with not more than 20% greater weight and/or power output than engines offered by the first manufacturer as a standard or optional engine.
Not sure if thats what your after but it may be.
Weekend AUII xr8
Daily 1988 F250 460
Hers Eb xr8
veqlargh is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2009, 08:36 AM   #3
zaczac
no, I know of that part but I am talking about major modification of total engine swap.
I had an old 1.5l excel that was fitted with 2L turbo (triple original power) and it was mod plated and rego'd etc
what I am trying to find out is what is max engine capacity you can put into a car based on its weight/original specs.
thanks
Old 07-08-2009, 02:29 PM   #4
388cube_edxr8
Nutty Professor
388cube_edxr8's Avatar
Yeah I'm pretty keen to find this out too, the Qld Govt website is a labyrinth of illogical stupidity.
Originally Posted by Jeremy Clarkson
If you buy a rubbish car, what you are saying is "I have no interest in cars." If you have no interest in cars, you have no interest in driving, and if you have no interest in something, it means you're no good at it, which means you must have your driving license taken away.
388cube_edxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2009, 05:42 PM   #5
GTP 290
GTP 290's Avatar
I was reading the rules just last week I'see if I caqn find where they were for you guys.
EDIT: not exactly what I was looking for but this is whats allowed in QLD
GTP 290 is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2009, 06:48 PM   #6
388cube_edxr8
Nutty Professor
That means that the biggest motor I can put in the Gemini is a 2.6T or a 3.8 N/A. It also means I cant supercharge the ED XR8, and my mate cant turbo his BA XR8.
GTP_290, you're time and effort is much appreciated, but are you sure this information is correct? Was there and additional notes or info that came with the above table?
Old 07-08-2009, 10:44 PM   #7
zaczac
I have seen this table in NSW I think, but does anyone have any hard evidence of QT rules re this??
Old 08-08-2009, 10:18 AM   #8
GTP 290
GTP 290's Avatar
Your best bet it to call someone that does mod plates, they will be able to confirm this table and also give you some tips and tricks to help you with your conversion.
As an example, the mazda RX7 series 1. In QLD it is illegal to put in a 13b turbo rotary however if you speak to an engineer they will tell you that it is because it has drum brake rear and is 50kg to light the they will tell you how to get around those problems.
You could call the department of transport but you will more than likely be waiting a while for an answer that will change with every person you talk to there.
EDIT: Also just noticed the second part of your post bud. The engine conversion rules are different to the power adding rules. You shouldn't have a problem adding a turbo or supercharger to vehicles that have the standard engine fitted although some cars are touch and go.
Old 09-08-2009, 02:33 PM   #9
zaczac
well I have sent an email to a guy who did mod-plate on my old car, so will see what he tell us.
