Old 26-10-2009, 10:44 PM   #1
SSD-85
Default Camshaft options for 220
As the title suggests, can an AU3 xr8 220 get a more aggressive camshaft without bumping up the max RPM? Or is it pretty much on the limit already? Be interesting to know if anymore power can be squeezed out of this thing....
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2009, 10:48 PM   #2
Windsor220
Now Fordless
Windsor220's Avatar
I too would be interested in this question.
Any other cams for the standard 220 heads and 1.7 rockers. Apparently the one in there is very mild.
Windsor220 is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2009, 01:17 PM   #3
CFOUR
The Destroyer
CFOUR's Avatar
kw increase will be minimal however changing the cam can dramaticaly improve torque curves. mine is nearly flat from 1800rpm to 5500rpm.
Toy- Blown XR8 Ute. Black on black
"Front-drive cars are for children"
CFOUR is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2009, 08:37 PM   #4
SSD-85
Sounds ideal. What is yours?
Old 02-11-2009, 10:29 AM   #5
CFOUR
The Destroyer
CFOUR's Avatar
sorry for the delay had to look it up
http://www.trickflow.com/partdetail....+&autoview=sku
^^cam im running^^
will cause break power assist issues with a a std stalled auto needs a 2700+ stallie or vaccum tank. works fine with a manual.
Old 02-11-2009, 09:31 PM   #6
SSD-85
^^cam im running^^
Any changes needed for the valvetrain?
Old 02-11-2009, 11:30 PM   #7
CRAIGAU3220
Cat be Still !!!
CRAIGAU3220's Avatar
Piston to valve clearance will be line ball if you run your std 1.72 rockers.
Also would pay to upgrade valve springs, Have a look on Trickflow website as i have heard they do a good spring package for ford cast iron heads.
CRAIGAU3220 is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2009, 04:38 PM   #8
CFOUR
The Destroyer
CFOUR's Avatar
I'm using 1.6 rockers. Pushrod length will change also.
Old 03-11-2009, 05:00 PM   #9
RG
Back to Le Frenchy
RG's Avatar
Any cam will require a valve spring change. The stock ones aren't even up to the job in stock form and are a known issue on the 220's.
Old 03-11-2009, 09:22 PM   #10
SSD-85
That's true. But im happy RR's dont change. Anyone care to elaborate on pushrod changes? as in what size do I need?
Ill get a vac. tank instead of new stall. Provided the cam's operating range is within the stall of course.
I am mighty tempted to change my diff gears to 3.45 too. As ive driven an EL XR8 (185kw) and that was a hoot to take off in. :
Old 03-11-2009, 10:36 PM   #11
old fordnut
too many fords
old fordnut's Avatar
If you've got an AU then they already are 3.45
Daily driver 1: [COLOR=Indigo] 2010 FG XR6 Turbo 50th Anniversary, BPR CAI, Plazmaman turbo pipe.
Daily driver 2: Nissan gq patrol
Project 1: XP ute, 351W, c4, 9inch
Project 2: XBGS sedan, sunburnt orange and vinyl, original 4spd, 302C.
old fordnut is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2009, 10:45 PM   #12
SSD-85
No, AU2 onward xr8's have 3.25....
Old 04-11-2009, 06:08 AM   #13
RG
Back to Le Frenchy
RG's Avatar
Actually they do have 3.45's. Jump under the back and have a look.
Old 04-11-2009, 07:58 AM   #14
old fordnut
too many fords
I've owned a series 2 and it had 3.45's. My parents have also owned a series 2 Xr8 and it had 3.45's as well.
Old 04-11-2009, 07:07 PM   #15
SSD-85
hmm odd, given what i've been told.....
Anyway I probably won't end up worrying about any of this. There is another Ford i'd much prefer at this point ;)
