Old 10-10-2009, 07:17 PM   #1
IH8HSV
XR6T 400kw(well one day!)
IH8HSV's Avatar
Default Bubbles in Coolant tank
Hi all...
When my engine is idling there are little bubbles blowing into the coolant bottle. When I increase the revs the bubbles increase.
Now I know straight away that the first assumption is a blown head gasket.
However the car runs perfect, no coolant loss and no water in the oil.
Before i start ripping the head off I would like to know if there is anyother possibility for the bubbles. I did change the bottom radiator hose last week. Could that have anything to do with it?
Thanks.
If it Vibrates, rattles, squeaks or knocks - then it must be a Territory
IH8HSV is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2009, 08:24 PM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Sure can. And i'd dare say that's your culprit. Perhaps run the car with the cap off until the bubbles go away?
Old 10-10-2009, 09:27 PM   #3
JC
JC's Avatar
Yep - spot on, I reckon. The old X series used to have an air bleed valve just under/near the thermostat that you'd crack open after changing hoses, or refilling the radiator, to let the air out. These days, after you refill the radiator, you need to idle for around 5 minutes with cap off to do the same job.
JC
Ford Performance Club ACT
Old 10-10-2009, 10:36 PM   #4
IH8HSV
IH8HSV's Avatar
Thanks fellas,
Thats what I was hoping to hear.
I will run the car without the radiator cap as you say, and see how I go.
Will post back tomorrow.
Cheers.
Old 11-10-2009, 12:08 AM   #5
ED Ford Falcon
ED Ford Falcon's Avatar
Yeah, get the car to normal running temp with the expansion tank lid off...if you are nearby it may even "burp" for you
1994 ED
2008 BF XR6
ED Ford Falcon is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2009, 01:10 AM   #6
IH8HSV
IH8HSV's Avatar
Haha...
Yep I hope so.
Dont have the time to change a head gasket at the moment. To busy with work around the house!!!
Old 07-11-2009, 07:53 PM   #7
Venomous1
5.0 means business
Venomous1's Avatar
Thanks So Much for this just had the same problem going to give this a try.
Windsor V8 Enthusiast!
Turbo Barra Lover!
Venomous1 is offline   Reply With Quote Multi-Quote with this Post
Old 07-11-2009, 11:21 PM   #8
IH8HSV
IH8HSV's Avatar
Thanks for the advice fellas. The bubbles were from the hose I changed.
Quite surprised how long it took for the air to bleed out though.
Best thing is - no head gasket! - Phew!
Old 07-11-2009, 11:24 PM   #9
Mr Hardware
yep - i knew it would be
