Old 14-10-2009, 09:30 AM   #1
fernsantos
Default Leaking from Transmission Extension Seal Area
AU2 6cyl Auto Fairmont Ghia
Just got the car serviced and the mechanic wrote on the bottom of the invoice that it is leaking from the transmission extension seal area.
Is this a big job to do and is it costly.
I am getting an auto transmission service done soon can it be done at the same time.
Any help will be much appreciated.
Regards
fernsantos is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2009, 10:39 AM   #2
frd906
i just did mine all up cost me 100 bucks, make sure you get your UNI joint done as well,
mine was flapping around in the gear box and ripped the main seal out
new seal, new extenstion housing seal, new uni join with a grease nipple, new shim or wateva its called which goes over the yoke plus labour cost me 100 bucks
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2009, 11:20 AM   #3
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Why didn't you ask the mechanic???
No and no is your answer.
Old 14-10-2009, 11:25 AM   #4
frd906
man i got mine done for 100 bucks mate rates, a mechanic will charger a arm and a leg
Old 14-10-2009, 11:36 AM   #5
blueoval
Critical Thinker
blueoval's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Well thought out and constructive posts.  A real credit to this forum.
yes, is cheaper for an transmission specialist to do it for you.
Make sure its a brass fitting. This will last the lifetime of the car.
The factory units were made from cheaper inferior chinese fittings due to cost savings. They are meant to last only a certain period of time. The brass ones are far more resilient and once done, you can forget all about it.
"the greatest trick the devil pulled, is convincing the world he doesn't exist"
2022 Mazda CX5 GTSP Turbo
2018 Hyundai Santa Fe Highlander
1967 XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 AU2 75th Anniversary Futura
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2009, 08:33 PM   #6
gregaust
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Greg always goes out of his way to provide assistance and support to members of AFF. Greg freely shares his knowledge with people who ask for help and often assists them with obtaining parts and repairs.  A great member of the AFF community. Technical Contributor: For members who share their technical expertise. - Issue reason: Always happy to offer assistance from his own experiences and often posts up photos when someone is having issues finding/locating something they are trying to repair or replace.
Most likely cause of seal failure is a worn bush, as mentioned above there is a BRONZE type rear bush is much tougher than the original types that wear pretty bad . Is easy done with extension housing removal. Special tool is needed to press the bush in .
gregaust is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2009, 09:43 PM   #7
Erich
Originally Posted by gregaust
Most likely cause of seal failure is a worn bush, .
What bush you talking about? Did I miss one?
What they are saying I think is a "speedy sleeve" is inserted on the yoke of the tail shaft to allow a nice surface for the new seal to run on as the yoke would have a groove on it - hence combating the seal leak.
Likely problems would have been seal creating a ridge in the yoke or worn Uni joint etc which will have play and end up streching/elongating the seal
Erich is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2009, 09:56 PM   #8
gregaust
There is a bush in the back of the extension housing in front of the seal. It is very common for them to wear bad in these 4 speeds . A new bush , a new seal and a nice smooth gearbox yoke is the fix. A speedy sleeve is NOT suitable for the tailshaft yoke
Old 14-10-2009, 10:04 PM   #9
Erich
then what if the yoke has a groove in it? Ive fitted quite a few - and they are a lot cheaper than replacing the yoke. Never had a car that is "not suitable" for a speedy sleeve
Didnt know about the brass yoke - I dont work on late model trans
Old 14-10-2009, 10:11 PM   #10
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
What Greg said
Get the brass/bronze bush they use in the V8's
To change bush drop tailshaft, (check uni joints while disconnected but they do 2-300000km normally) 4x 12mm bolts undo extension housing, (may have to undo some counterweight bits cant remember back to AU 100%) find suitable socket and knock bush out. Knock new bush in , make sure same way as old one to line up oil hole, new seal as well, reassemble.
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2009, 10:15 PM   #11
Erich
ty Jastel & gregaust - didnt know about the bush
Old 14-10-2009, 10:20 PM   #12
gregaust
The way to tell what bush is the original are a grey colour and a soft type whitemetal sort of lining. Not uncommon for most of the bearing lining material to be worn away to the steel backing .The bronze types are much more robust and of course are a coppery bronze colour lining.
If there are grooves worn in the yoke you'd be better IMO to source a new yoke . Speedy sleeves work well on narrow fixed running surfaces but never seen one on a yoke that moves/slides back and forward if that makes sense..
Old 14-10-2009, 10:27 PM   #13
Erich
it does - and yes - speedy sleeves are an inteference fit and stationary - they bind to the yoke
Old 12-11-2009, 02:39 PM   #14
fernsantos
Smile Job as been done thanks for your advise very happy with the outcome
Got the job done today total cost $440 maybe a bit on the expensive side but i am happy with the place i took the car to.
Auto service
Fluid flush
Supply & Fit rear transmission oil seal(brass)
Supply&Fit new rear extension bush
Thanks for everyones input.
Old 12-11-2009, 02:42 PM   #15
frd906
yeh $440 is a bit steep, oh well at least you got the job done
Old 12-11-2009, 02:51 PM   #16
blueoval
Critical Thinker
blueoval's Avatar
I think the extra dough would be in the flush. But good to know you can rest easy.
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 12-11-2009, 04:18 PM   #17
The Monty
Just slidin'
The Monty's Avatar
$440 is right on the money including a flush. At least its all fixed now. On a side note, just to do the extension housing seal for me for the first time took about 20 minutes with the car on the hoist and cost $16.95.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 12-11-2009, 04:22 PM   #18
BIGJB
BIGJB's Avatar
$440 definately the right $$ for the work done.
Best of all you know it's all done and right now.
BIGJB is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2009, 09:29 PM   #19
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
they are ven more prone to doing the extention housing bush when you have lower diff gears also. i have 4.11's and am getting my 2 one in 50,000 km's done
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw)
2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned)
Mr_4.0 is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2009, 05:33 AM   #20
The Monty
Just slidin'
The Monty's Avatar
Im sure with me, launching on slicks probably didnt help it much, lol.
