Old 13-11-2009, 05:35 PM   #1
TheInterceptor
Cruising...
TheInterceptor's Avatar
Default Semi Auto??
Hey, anybody know if semi auto can be installed into an auII??
Is it possible or am i dreaming?
TheInterceptor is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2009, 07:24 PM   #2
frd906
like, manualiseing the auto
so your 123d are actual gears and you have to use the tbar to change gears,
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2009, 07:51 PM   #3
White_sr_taxi
JC had a go with a b series style setup, sounded like not worth doing, search for his thread on it if you look for sss shift.... i think? from what i readed not worth the trouble but possible.
White_sr_taxi is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2009, 09:57 PM   #4
JC
Miami Pilot
JC's Avatar
Agree 100%!
Ford Performance Club ACT
Old 13-11-2009, 10:06 PM   #5
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Helpful and detailed posts on car care.
would be interesting if you could do an F1 / Ferrari 'paddles' setup!!!
No longer an 'active' detailer.
Dave_Obsession is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2009, 10:09 PM   #6
JC
Miami Pilot
JC's Avatar
Data_mine is building such a set up for a BA GT; I guess if he is successful (and he may already be - haven't seen the thread for a while), then all you'd need is Muzza's "BA for AU" electronics, an E series valve/solenoid in the box to hold 1st and the Data_mine paddles and it would work in an AU too.
Old 13-11-2009, 10:11 PM   #7
kenz
BOSS Pilot
kenz's Avatar
I think he finished that a while back and it came up good. I remember seeing something about it but not having an auto I wasnt highly interested in reading it all
Black BAII XR8 Ute
Blue SY Territory Ghia
Originally Posted by CAT600
No matter how good the F6 is (and it is damn good), its missing two cylinders.
kenz is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2009, 10:30 PM   #8
JC
Miami Pilot
JC's Avatar
That would be perfect then - get the SSS controls on the wheel, and no unsightly BA shifter! Still, it would be around $1k all up, so hardly worth it. I just go up and down the gears manually; never had an auto break on me yet (except the EL, but it was stuffed anyway!).
Old 14-11-2009, 09:02 AM   #9
DJM83
Barra Turbo > V8
DJM83's Avatar
T Series ESS setup?
-2011 XR6 Turbo Ute - Lux Pack - M6
-2022 Hyundai Tucson Highlander Diesel N Line
Old 14-11-2009, 11:01 AM   #10
T3man
T3man's Avatar
The T-Series ESS set-up is the best auto changer EVER! It is the nearest to full manual control that you can achieve without actually having a full manual valve body like on the old FMXs and C6s etc. I wish someone would do something like that for the BW auto.
Old 14-11-2009, 11:20 AM   #11
InfernoSR
Sales Representative
InfernoSR's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For research and posted write up on cooling system care and repair in AU.COM and offering help where possible
I used to have the details required for fitting the sequential shift from the B-series into an E-series, using the E-series gearbox... was advised to use a custom shift kit to stiffen up the shifts for the AU box... will look for the email if requested...
InfernoSR is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2009, 11:50 AM   #12
DJM83
Barra Turbo > V8
DJM83's Avatar
Agreed
Old 14-11-2009, 11:56 AM   #13
FPV+fteT3
Performance Inc.
FPV+fteT3's Avatar
A good tuner and a flash box can stiffen up the shift in an AU box. Chris from bluepower has tuned my TE and the full race tune the box shifts at max revs if left in auto mode and for want of a better word slams thru the gears so sharp that when you first experience it you would think the box is coming thru the floor I do not use that tune for street work the middle tune 220rwkw the shifts are crisp and not as harsh on the box and it changes before redline in auto mode.
In The Garage...
FPV Super Pursuit Build no 0080/91
Lotus Exige S/C S240
Kart Hasse Chassis 100J Power
Originally Posted by flappist
Rental cars, the equipment of choice to get to destinations where 4WDs fear to drive......
FPV+fteT3 is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2009, 03:36 PM   #14
blueoval
Critical Thinker
blueoval's Avatar
I too was looking at this mod, but am thinking of going full manual valve body, and strengthened internals. I think it will be very difficult to get my hands on a ESS from a T series.
"the greatest trick the devil pulled, is convincing the world he doesn't exist"
2022 Mazda CX5 GTSP Turbo
1967 XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
Old 14-11-2009, 07:17 PM   #15
TheInterceptor
Cruising...
okay, gettin the AU a flash box and a good tune up...
OR
stick in a B series box?
Old 14-11-2009, 08:28 PM   #16
Lukeyson
Right out sideways
Lukeyson's Avatar
lol just enjoy for 2 sec lag after you hit the shift.
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302
Lukeyson is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2009, 09:37 PM   #17
JC
Miami Pilot
JC's Avatar
OR
No point going to a B series box - it's the same as the AU, but with cheaper (chinese?) internals and is weaker than the AU box. A box from an EF or EL would be a good one to use for this mod, as it already has the correct valvebody required to hold first gear (the AU box doesn't; the BA box does, but is weaker).
The BA SSS function is all electronics, with the only addition being the BA shifter which is made to move sideways. Get all the gearbox electrics from a BA, and the shifter and cable, and a weekend, and you'd have SSS in an AU (just don't expect it to hold in 1).
Old 14-11-2009, 09:46 PM   #18
TheInterceptor
Cruising...
Sweet thanks, is there anywhere i could take the au to get all this installed? or is this basically a weekend project?
Old 14-11-2009, 11:26 PM   #19
JC
Miami Pilot
JC's Avatar
I'd contact FTG - they're always good for doing weird/odd/great stuff.
