Old 17-12-2009, 06:11 PM   #1
TK-421
Default Centre dash panel removal AU1.
Just wondering how the panel is removed? the round panel with the radio.
TK-421 is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2009, 06:28 PM   #2
sikford
THE Fairmont Ghia 75th
sikford's Avatar
its all clips except u have to remove the head unit first then it has a screw either side that needs to be removed then the 2 behind the ashtray then it should all pop off.
Current Ride : AUII Fairmont Ghia : 75th Anniversary Limited Edition
Current Mods-HD Built Gearbox+(Mirror Polished, Modified Valve Body), 2500rpm Hi-Stall Convertor(TCE Custom Built), BIG Trans Cooler, Braided Lines/Speedflow Fittings, 2.5" Exhaust, Custom CAI, Detailed UnderCarriage, Custom SQ Stereo Install.
My Ride
My Build Thread
sikford is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2009, 10:41 PM   #3
TK-421
ok, thanks.
Old 18-12-2009, 12:17 PM   #4
superroo
You can't stop the signal
superroo's Avatar
http://www.fordforums.com.au/showthread.php?t=95787
http://www.fordforums.com.au/vbporta...warticle&id=37
