#1 | |||
Formerly mad_ed_wagon
i done a headgasket change to my ghia last week, finally managed to get it driving and out of the garage today, but it seems to still have a few problems,
1st, the injectors have to be in exactly the right position to get it idling right 2nd, once you accelerate it makes a "putt putt putt" sound then starts to rev up 3rd, 0nce on the road, it really lags and idles rough, and once i accelerate still makes the "putt putt putt" sound before it starts moving 4th, the exhaust, when the cars in park & idling, has a stop in it's blow, it sort of blows then stops then blows then stops etc... making a "putt putt putt" sound again (i checked this on the ED and the ED's exhaust blows constantly) and, when the head gasket was blown the car was blowing water out the exhaust and still does if i rev it a bit or it's on my drive way (on an angle) so i've sort of run out of ideas on whats up with it..., any one got any ideas on what could be wrong and how to fix it?
2004 BA FALCON XT/GHIA WAGON Build thread coming soon! Quote:
#2 | |||
and by lags... i mean it feels like it has a 2cyl engine in it!!!
Smash the Boost
Timing is out. When I did the head gasket on my EA i setup the timing per timing marks as normal. Turns out my balancer had slipped. I had to then find TDC myself with a coathanger down number 1 plug, mark that with a paint pen, and go from there. Was all good after that...a 1.6L auto laser flogged me off the lights prior to doing all this, so I know how slow it must feel
it also sounds like its misfiring. How are the leads, plugs and dizzy cap/rotor?
2023 Hyundai Palisade 1971 Fairmont Sedan 1974 SWB F100 Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
hibernating
Yeah sounds like timing is out.. or it could even be missing as well? Umm no idea about turning injectors for it to idle right though that sounds weird
Smash the Boost
I just pulled all the inlet out of the way when i did mine lol.
#6 | |||||
myght just aswell visit JR's and get some injectors, might be the seals or something that are gone (at least thats what my dad says)
If you have to rotate your injectors to get it idling right they are rooted. They should be firing a cone spray, obviously they aren't.
#8 | |||
its not a!
From what ive heard thats a good thing, show its burning nicely. |
Water is a by product of catalytic convertor operation.
#10 | |||
so how come my ed or my old ea dont do it?
How much water depends on what gases the engine is putting out. No two will be the same.
#12 | ||
likes falcon's
playing with injectors was only a suggestion as i figured not everything was perfect and clean wen it was bolted back together... i had a mate come around once, "nik man my cars idling like a prik"
i had a look and an injector plug come out lol
www.carhubsales.com.au |
#13 | ||
Two > One
water is a byproduct of combustion. Depending on the batch of fuel will impact on the H2O quantity. LPG cars drip water something chronic.
1978 LTD - 408ci - 11.5@120.6mph - 2004 S4 - 4.2 - M6 - quattro - |
#14 | ||
Did you make sure the timing chain didnt skip a tooth on the cam gear, usually use two zip ties around the chain while on the gear. Were all the leads numbered, if not double check that there in the right order. The dizzy shouldn't be out, its not usually moved when doing the head, so unless you did move it i wouldnt change its position, but changing the cap and leads is fine. Thats a few things
![]() Also if the oil is still creamy (has water in it) it can cause the lifters not pump up correctly, causing it to miss.
Proud Owner of 06' TTG |
#15 | ||||
& leads were numbered
#16 | ||
Custom user title
is it on gas as well?
#17 | |||
Low and Loud
If you need a set of injectors, ive got a spare set of working EA ones
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon ![]() |
#18 | |||
it's on gas but doesnt run on gas yet, gotta fix that still
