How do they work and what is the purpose
Official AFF conservative
Amazing thigs, torque converters.
A "high stall" converter is simply a torque converter which has been designed/modified to increase the RPM at which the converter is said to stall. http://auto.howstuffworks.com/torque-converter.htm
A cup half empty... but full of euphoria. |
The one and only
The 'work' part can be difficult and technical to explain.
Their purpose is to alter the RPM that they are efficiant at and their torque muliplying factor. Simply, the cam works from 2500 the car would 'bog down' under this so it would suit the drivability to have the converter to slip up to this RPM. A high stall is pointless and a money waste until the engine is built, it is not a case of walking into a shop and asking for a 2500 to suit EF for example. Also the diff gears will also need to be changed for optimum performance gains.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
so it doesn't idle at the revs its named(2500 stall converter)...wats happens when u put your foot down...does it rev untill the stall and then engage...i'll read up on that link too
thnx guys |
Oops, I slipped....
It doesn't rev then engage at 2500 (eg: for a 2500 stall). If you put your foot on the brake and pull the handbrake, a stock Falcon torque convertor will rev to 1800-2100 (depending on engine) whereas a 2500 will rev to 2500, thats about the easiest way I can think of explaining it.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
Smash the Boost
You can also flash a converter whereby you stand on the gas from idle and the converter will have a different stall speed again (usually higher) depending on the engine
they seem to me to be complicated things but im learning
2023 Hyundai Palisade 1971 Fairmont Sedan 1974 SWB F100 Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
i get it now
so basically it stalls higher lol i think i was trying to be too complicated with my thoughts i didn't put it into a practical scenario...ive stalled up my auto for burnouts or to get off the line quicker..when i thought of it that way it makes more sense |
#8 | |||
Just think of them as the equivalent of the clutch on a manual box. Normally you want to rev to about 1500 or so then start letting the clutch out. On a performance engine when you want to drive hard, you would rev to about 2500-3500 or more before you let the clutch out. Same idea with the stall convertor. You decide when you want the power to be locked to the back wheels and get the matching convertor.
the difference is that with an auto/stall convertor, you will still have some power being put to the wheels at lower rpm - just not all of it. Kind of like slipping a clutch I guess.
sweet sounds like a mod i need to do
thnx for the info i understand it now so just say i got ya normal stock slushbox with a shiftkit...wat stall converter would be applicable for my eb and how much do they cost |
#10 | |||
A hi stall converter is used when you need to get the revs up due to cam/head/whatever pushing the power band further up the rev range. Refer to LTDHO's post above.
#11 | |||
Rolling on Simmons...
Ive been in an EF XR6 with a 2500 stally, was pretty cool, much like dumping the clutch and flooring it in a manual. stomp on this thing and it would go straight to 2500 and start spinning
The daily hack... 1994 ED XR6 5Spd, Simmons FR17"s, SupaLow's, Sprint Bodykit, Cam, exhaust and all that jazz... Complete AU XR6 conversion and soon to be turbo! :voldar02: Quote:
#12 | ||
ok well i don't have cams
just headers hi flo cat exhuast and pod so i'm guessin a high stall wouldn't be needed.. but as per using it just to stall up to the revs and drop...is that stupid? i want like a 2500-3000 one cos my eb off the line is a tank |
#13 | ||
Smash the Boost
thought about diff gears?
#14 | ||
yeah i thought about that
my mates got an eb and just got given some diff gears...i wanna see how that gos on his |
#15 | |||
thats sounds mad |
#16 | ||
Oops, I slipped....
2500 is the safe limit for a torque convertor on a BTR, the TCM/ECU weill go into limp home mode (LHM) if it stalls to over 3000 rpm.
I have a 2500 TCE convertor in my car and it made a decent improvement, and i'm using stock heads/cam/manifold. Cost for a high stall convertor is around $900 fitted, ring around for prices.
#17 | ||
thanx man
wats BTR? |
#18 | ||
Oops, I slipped....
The company that builds the 4-speed auto's for EAII-BA Falcons
#19 | ||
NO CARBON TAX
imo dont run a stall higher than what your cruise rpm is, as you know it wont be locked and will loose power and fuel eco.
THE WORLDS FASTEST BISCANYE BLUE EB FALCON WITH EB BLOCK AND HEAD!!! NO AU **** THANKS Atomic performance engine, powerglide, coan converter, gtx55 turbo, 2000hp plazmaman water to air, 100mm throttle body, twin 50mm gates, side exit exhausts, 18 x 2200cc injectors, ems 8860 and race dash....... 7.83 @ 177 MPH 1100+ rwhp @ 40psi the first 7 second sohc ! eat it 1993 eb falcon 15.4 @ 90mph (tow car) |
#20 | ||
Oops, I slipped....
I have no problems at cruising speed on mine, the stall speed doesn't have anything to do with the torque convertor lockup. It still locks-up at 1500rpm in 4th if I want it to.
#21 | ||
Smile
Reasonable torque converter is rated at a certain rpm .However if you put out more engine torque the stall goes higher. 2500 stall converter is definately a streetable combo on a standard car . I have done my homework well.Also another factor is that torque converters have torque multiplication which manuals do not have. If your car puts out 300ftlbs of torque at 3000 rpm torque converter can deliver 600ftlbs of torque with a multiplier of 2.The au ford has a multiplier of 2:1. Just changing the multiplier to 3:1 should make the car chirp in gears and of course take advantage of a greater amount of engine torque at the higher engine speed.
A 2500 stall converter can stall up to 3000 rpm flash with a bigger cam and tricks.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
#22 | ||
Smile
#23 | |||
NO CARBON TAX
