Old 08-02-2010, 06:27 PM   #1
cougermoon
Mr blue
cougermoon's Avatar
Default Power Steering (i think)
Hey all,
today i got home and noticed some oil on my driveway, took a look under the car and saw that it was leaking a bit of oil. It looks to me like its power steering fluid, but im not sure, im not an expert. I rang midway ford, the people i bought it off and booked it in for them to take a look at, but i would like to be able to tell them exactly what the problem is to save time. I was wondering if u guys could have a look at the pic and tell me what it looks like the issue is.
(sorry for the angle, the bricks i was sitting on were bloody hot)
There is no leak i can see looking in from the engine bay ( to eliminate the idea it leaking from further above).
only one or 2 droplets come out after i turn the car off after a drive but thats it, still id like to know what it is.
any help would be great
thanks
Will
cougermoon is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2010, 06:40 PM   #2
svo supporter
Fixing Ford's **** ups
svo supporter's Avatar
I'd guess it'd be the o'ring/s from the power steering hose/s where it goes into the rack. They tend to get brittle and start to leak after a while.
Let us know whether that's right or not
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises.
Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here
Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone
svo supporter is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2010, 07:18 PM   #3
Check the power steering switch - blue switch just above where the circle you drew joins. These often fail and leak.
Old 08-02-2010, 09:10 PM   #4
mik
mik's Avatar
have a look at your alternator , see if theres any oil on it.
Old 08-02-2010, 11:56 PM   #5
cougermoon
Mr blue
cougermoon's Avatar
Yeah ill have a look at the switch and the alt in the morning, it could possible be them(didnt consider them at the time). but the idea its a hose or an O ring thats just old seems logical for the area of the leak.
Ill know 2morrow morn and ill post back with what it was for interest sake
thanks heaps
Will
Venom-Red AUII Forte
Engine Mods:| 4499's Pacies | 2.5" single muffler Redback Cat back | Hi-Flow Cat | Custom intake 3" | SS CAI snorkel | BM Hi-Flow Filter |
Visual Mods:| Clear side indicators | Tickford Wings | XR dash cluster | Black gear surround and shifter | Painted brakes | 18" BF XR8 mags | Black chrome tail lights
My Build
Old 09-02-2010, 12:15 AM   #6
all4fordau
Another vote for the power steering switch. I have had mine done twice in about 5 years. If I remember it is in a difficult spot to remove and replace, and I had to make up a special spanner to get at it.
all4fordau is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2010, 12:57 PM   #7
cougermoon
Mr blue
cougermoon's Avatar
yeah you were right, turned out the hole pump and high pressure switch are going. I havent ever had an issue with them, and i guess cos it hit 130, 000ks now it was bound to happen.
gonna cost 600 to put a new pump in and switch.
but the mechanic rekons everything else is sweet on it.
so ill see how it turns out.
(i was praying it was just a buggered hose :( )
thanks for the advice people
Will
My Build
Old 09-02-2010, 05:05 PM   #8
AMB
Technical Contributor: For members who share their technical expertise. - Issue reason: Always has a helpful answer in the technical sections, wether it's giving information on a simple diagnosis with a small issue, Helping someone fix their car if they are stuck on removing/installing something, or just need information on what works how.
Just change the switch, the pump will probably keep "going" for another 5 years before it goes. It'll just get noisier.
AMB is offline   Reply With Quote Multi-Quote with this Post
