#1 | |||
Thought this might be interesting. One run with BBM locked in short runners, one run in long. Might help people decide if a BBM conversion is worth the effort or not.
Bloody hell......I didn't think it made that much difference!
I'd say the BBM is where 90% of the power upgrade from the ED's 148kw to the EF's 157kw is.
2003 Narooma Blue BA XR6 5spd Manual. Pacemaker 4490 Extractors 2.5" Exhaust High Flow Cat SS Inductions "Growler" CAI Underdrive Pulley Mal Wood H/D Clutch Custom Tune 18" XHP Sabre's 12" Kicker Sub 169.2 rwkw
#3 | |||
to the best of my knowledge, the ED (and previous) manifolds were about the same as the BBM on short, so the gains you get by swapping are the low end (where you do most of your driving).
#4 | |||
Does Steve have a car?
AKA Mr Silver Chasing reliability.... ![]() "When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
#5 | ||||
bloody interesting. Looking at that, you'd want the runners to swap over about 4000rpm not any earlier. IMO, I'll still stick to the good old ED manifold....never been a fan of the BBM.
hibernating
interesting dyno chart... it does give a decent increase down low and midrange.. i can't really be bothered changing to it though :p
#8 | ||||
RIP...
BTW, 'stockstandard', I did the same test on a dyno ages ago, and torque between 2500rpm-3500rpm had actually improved by approx 40nm. Rick.
. Oval Everywhere... |
Kurucu Performance
I've done the full conversion and have realized there is more power down low but up high i think it can be better....my max power output has dropped by a few odd kw...
174rwkW N/A I6 Kurucu Performance Enhanced... Heathcote Test & Tune 28/08/05 - 14.0902 @ 97.61mph Now With EL XR6 Engine & ECU & 3.7 Gears Www.KurucuPerformance.Vze.Com |
#10 | |||
RIP...
Rick.
Kurucu Performance
So we can do better down the quarter mile maybe....power is good for burnout already...whats 40nm gonna be good for down low?
Getting the car off the line maybe.
#13 | |||
Two > One
1978 LTD - 408ci - 11.5@120.6mph - 2004 S4 - 4.2 - M6 - quattro - |
#14 | ||
hibernating
The main drawback about changing to bbm is that you also need to change ecu for it to work good... and then my little trip computer would be useless! But yeah it does provide a good increase all below 4000rpm.
What would also be good to see is an eb manifold compared against an ef/el manifold on the same car using the correct ecus |
#15 | ||||
#16 | ||||
#17 | |||
RIP...
You don't drive it on the road, but when you have to, you always have the revs above 5000rpm, correct? Rick.
#18 | ||||
RIP...
The log manifold curve looks essentially like the BBM when it's on short runners, which makes sense as the the runners are approx the same length. The BBM's long runners are approx twice the length. Rick.
#19 | ||
Kurucu Performance
My conversion of the BBM involved changing the ecu and doing it the proper way...i am running an el xr6 ecu now...it is running the BBM switch and i have hooked up a noc sensor...b4 however i was running the standard eb/ed manifold with my ed xr6 ecu... the difference is nothing worth noticin...i have had it dynoed both ways on the same car...just gotta get the graphs scanned so i can post them up....cheers...
#20 | ||
Last warning
the BBM goes hand in hand with an aftermarket ECU too.
where u can decide exactly where you want it to switch the runners for a smooth transition. the feeling of my car when i ran with them undone was amazing, i know my ignition timing etc is set for it, but still a fair change.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
#21 | ||
Turbo Dinosaur FTMFW
heh, i'm running around in my EB at the moment with the BBM locked on short runners...
for some reason the switch isnt switching. gotta love cable ties ;) |
#22 | ||
PM me if you want
If you have tied shut that is long runners
#23 | ||||
#24 | |||
hibernating
One thing I also dislike about the bbm is that the intake pipe needs to be alot longer and curves in a 180 degree bend... the eb intake pipe is shorter and less bends.. which seems a bit better |
#25 | |||
No doubt tuning will change the way it feels. Just saying if you dont notice the difference a BBM makes then it isnt working as it should. Whether or not the extra power is worth the effort is another matter. Considering the amount of time engines spend <3800 compeared to >3800 I think it is worthwhile even though it wont help you win any dyno comps or improve your 1/4.
I tend to agree with you with the intake setup. Although it does flow more than enough, I think ford could have done a much better setup by swapping the battery and airbox over. Would have a nice straight pipe from the TB to the box then.
#26 | |||
PM me if you want
#27 | ||
hibernating
I've always thought that would be a good idea dellboy... I can't understand why they faced it that way and made the intake loop around.. throttlebody should be facing towards the passenger side of the car.
#28 | ||
PM me if you want
If someone has done it, will save me checking, otherwise one day sooner then later I will test the theory cause I want to
![]() I think it will get a little messy on the runner switching side of things to change, but anyway.
#29 | ||
Where is the knock sensor fitted on the EF/EL?
Do u need it if u do the BBM conversion to an EA, if so how and where do you fit it????? I mean physically not electrically. I am running an EL ecu at the moment. Cheers |
