Old 20-01-2005, 09:53 AM   #1
V8 Ghia
Formally ED I6
V8 Ghia's Avatar
Default HELP EA Diff problem
OK heres the problem, my EA ghia (5sp with 3.23 on diff tag) makes a grinding noise the slower i take off and occasionally a clunk turning through slight bends.
No noise or clunk under clutch dump from 1500-3000rpm, taking off straight or turning.
Worst noise is at 5-10kph with the clutch in or out makes no difference (So i doubt its the gearbox). The LSD virtually doesn't work at all.
Is it the clutches on the LSD are stuffed and the rest of the internals are intact??
Am I up for a new diff or is it possible to just remove the LSD clutches (I dont care if i have LSD or not on it as its almost stock).
Daily driver
98' AU 349ci Fairmont Ghia on LPG
Other
93' ED 5spd 4.0L NA Fairmont
13.75 @ 101mph
V8 Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2005, 09:56 AM   #2
niko
likes falcon's
niko's Avatar
checked everythings nice and tight underneath?
www.carhubsales.com.au
niko is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2005, 10:06 AM   #3
V8 Ghia
Formally ED I6
V8 Ghia's Avatar
Yeah, there is no slack in the uni joint or the tailshaft.
Daily driver
Other
13.75 @ 101mph
Old 20-01-2005, 10:12 AM   #4
lv619
lv619's Avatar
I think one of the teeth from the side gears in the diff are worn/broken (too many burnouts...), so maybe thats why you hear a clunk when turning.
Me fail English? That's unpossible.
lv619 is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2005, 10:25 AM   #5
V8 Ghia
Formally ED I6
V8 Ghia's Avatar
Thats what my ED is for.
Yeah i agree the clunk is most likely from a worn gear, but shouldn't it clunk on a fast take off??
I ask the question about the LSD clutches because when i bought the car, the LSD didn't really work, but apart from that the diff was perfect. Recently the diff whine has been getting louder, and the grinding noise at snails pace has been getting worse.
Daily driver
Other
13.75 @ 101mph
Old 20-01-2005, 12:41 PM   #6
Bass Crazy
Hey my diff is exactly the same!
I have been a little slack to pull it down (Been the same for about 1 year now), but 95% sure its just the clutches chattering. The clutches need to be re faced, and given a little extra shim. Don't bother trying heaps of different oils, didn't do much for me.
Simon
Bass Crazy is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2005, 01:52 PM   #7
V8 Ghia
Formally ED I6
V8 Ghia's Avatar
Great so if i just put up with the noise it should keep going for a while yet.
What are the implications of driving with a worn diff, will it damage anything else??
Daily driver
Other
13.75 @ 101mph
Old 20-01-2005, 03:18 PM   #8
pepsimax
pepsimax's Avatar
could also be the axle bearings to,,they make funky noises at different speeds..
NO ONE DIES A VIRGIN AS THE WORLD SCREWS US ALL :thebirds:
pepsimax is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2005, 03:42 PM   #9
Mike Gayner
Mike Gayner's Avatar
Every time a diff starts making noises like that for me, it has died soon after. Admittedly, I tend to thrash them even after the noises start, and they tend to die soon after (or during) the thrashing.
Mike Gayner is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2005, 03:47 PM   #10
V8 Ghia
Formally ED I6
V8 Ghia's Avatar
In your thread you killed single spinners didn't you?? Fantastic effort to do it in a stock auto so many times.
I killed the single spinner in my ED, diff bounce tends to do that (Full LSD conversion/rebuild wasn't cheap). But when that happened it was a loud bang/crack each time i tried to take off hard.
Daily driver
Other
13.75 @ 101mph
Old 20-01-2005, 04:04 PM   #11
nutrok4
Posts: n/a
mike gayner do you ever come to tokoroa?
cause if you do you should show me your car
Old 20-01-2005, 05:43 PM   #12
Mike Gayner
ED I6 - actually the first diff I destroyed was an LSD, but it was shagged and started acting like a single spinner mind-burnout ;)
nutrok4 - my EA really isn't much, it's almost 100% standard now :P I used to have 4.11:1 LSD, K&N, extractors and zorst, but I blew the 4.11s and replaced with a cheap 2.77:1 single spinner (which is dead now aswell, replaced with a 2.92:1 single spinner), muffled up the zorst because I got sick of the sound and replaced the K&N with a normal paper unit to reduce noise. So yeah, my car is now a stocker and I'm saving the pennies for a V8. I've lost all motivation to do up a six, they just don't sound like a V8, and don't have half the street cred.
Old 21-01-2005, 08:18 AM   #13
Bass Crazy
It should just get progressively worse as the clutches surface glazes more. If you have the time, its would be better to fix it. If you leave it too long, you may not be able to salvage the clutches.
