Old 04-06-2010, 05:43 AM   #1
atomiclord
I drive way too much...
atomiclord's Avatar
Default Question about AUIII Instrument Clusters
Short and quick: Can I change the cluster in my AUIII Factory LPG-only Forte to an XR or high-series cluster? If so, how?
AUIII Straight LPG
Done: BA XR6T Snorkel, K&N Panel Filter, EL Belt Cover, 2.5" Exhaust
To Come: Extractors, Tran. Cooler, Lowering, High-flow Cat
atomiclord is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2010, 09:21 AM   #2
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Yes but needs some work
http://fordforums.com.au/search.php?searchid=4426094
will show you some of the posts
UK
Old 04-06-2010, 08:30 PM   #3
atomiclord
atomiclord's Avatar
It's not bringing up any search results?
I'm guessing the LPG wording etc will show up on most clusters that I could put in the car?
AUIII Straight LPG
Old 08-06-2010, 11:17 AM   #4
cougermoon
Mr blue
cougermoon's Avatar
have a look at my build thread as ive done this, there is also a small write up on this somewere on the site, god knows were though
Venom-Red AUII Forte
Engine Mods:| 4499's Pacies | 2.5" single muffler Redback Cat back | Hi-Flow Cat | Custom intake 3" | SS CAI snorkel | BM Hi-Flow Filter |
Visual Mods:| Clear side indicators | Tickford Wings | XR dash cluster | Black gear surround and shifter | Painted brakes | 18" BF XR8 mags | Black chrome tail lights
My Build
cougermoon is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2010, 04:04 PM   #5
broken_suave
broken_suave's Avatar
The only issue is the LPG. The signal may not be the same.
05 BF XR6 ZF 6spd - Stock for now
Previously:
98 AU Futura 4.0 - Wildcat Extractors, 200cpsi Stainless Cat, Custom 2.5" Mandrel Bent Exhaust, Tickford Snorkel, Fram 'Airhog' Panel Filter - Daily
79 P6 LTD Silver Monarch - Project
broken_suave is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2010, 06:34 AM   #6
atomiclord
atomiclord's Avatar
I read your little writeup cougermoon -- it's actually what got me started on this
I guess I'll put this on the backburner until I have a hundred or so to spare, just incase it doesn't work properly.
AUIII Straight LPG
Old 09-06-2010, 11:01 AM   #7
cougermoon
Mr blue
cougermoon's Avatar
Yeah, after doing it i don't think it was worth the trouble really, i mean it looks great but it wares off pretty quick and it was hell trying to do it all with the little knowledge i did have.
If i had my AU time over i wouldn't touch the inside, my focus would be some external mods and everything else on the donk, the inside of any AU is perfect IMO
Good luck
Will
My Build
