Old 20-08-2010, 11:10 PM   #1
atomiclord
I drive way too much...
atomiclord's Avatar
Default How to safely jack car?
Don't laugh, but I've actually never jacked a car by anything but the light of my mobile phone at 3AM in pitch darkness with the emergency jack for blowouts. Nobody to show me how to do it properly so I figured I'd ask the aufalcon gurus
So today I bought two 1T car ramps for general servicing, a 2T floor jack and two 3T stands for getting the rear up.
Is this setup alright? I should be able to:
- drive up the ramps general servicing
- jack up the front and place stands under the front to change front wheels
- jack up the rear and place stands under the rear to change rear wheels
- drive up the ramps, jack up the rear and place stands under the rear to have the whole car up for servicing
Anything I've missed or done wrong?
Also, where do I jack the car up? Obviously not the alloy crossmember at the front, and probably not the live-axle dif? Where do I place the stands at the front and the rear? The car manual doesn't really help.
Does anyone have a picture this could really help. I'm a visual learner.
AUIII Straight LPG
Done: BA XR6T Snorkel, K&N Panel Filter, EL Belt Cover, 2.5" Exhaust
To Come: Extractors, Tran. Cooler, Lowering, High-flow Cat
atomiclord is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2010, 11:17 PM   #2
KR1STO
Just another mock-up..
KR1STO's Avatar
Ok, before we get onto jacking the car up for maintenance...
No offence, but, have you ever done routine maintenance, servicing etc before..?
If not, I strongly recommend not touching the car by yourself..
Even jacking the car up by yourself...
You really need to be shown in person, not by a typed description over the net..
Sometimes the written word is misinterpreted and problems can arise..
Just my opinion...
BTW.. You've purchased the right stuff!!
Kris
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2010, 11:33 PM   #3
atomiclord
atomiclord's Avatar
None taken, thank you very much for your concern.
I've done the basic service my last couple of 4cly nissans and the girlfriend's car just fine, my long lanky arms could just reach in for the oil filter, sump plug, dif drain plug etc After reading through the great guides by people like GK I'm planning to change the auto box filter and dif fluid on sunday, if I'm feeling ready.
I'm really just confused because I searched for 'jacking points' to double check and found threads filled with conflicting information.
Here's the illustration in the gregory's manual. Is there any problem with these jacking and stand points?
AUIII Straight LPG
Old 20-08-2010, 11:38 PM   #4
KR1STO
KR1STO's Avatar
Good to hear mate!!!
Yep that looks about right...!
Yours will be live axle i presume so using the trolley jack on the two spots marked will be fine...
Just double check that its seated properley before jacking up the whole way and before reaching under to put the stands..
There's plenty of info in the AU guides to follow such as GK's one.. I think you'll be surprised how easy it all can be..
If you do run into any trouble there's always here....
Good luck with it mate!!
see my car here:
[SIGPIC][/SIGPIC]
Old 20-08-2010, 11:47 PM   #5
Road_Warrior
Pity the fool
Road_Warrior's Avatar
Chock the diagonally opposing wheel before you start jacking the car mmk. Housebricks or a big bit of wood will do.
Fords I own or have owned:
1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD
Proud to buy Australian and support Ford Australia through thick and thin
Road_Warrior is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2010, 11:59 PM   #6
atomiclord
atomiclord's Avatar
Thanks! Yep basic live axle forte.
Yeah, the couple of recommendations I found to jack the car from under the sills seemed a bit shonky.
Is a grooved wooden spacer required for jacking the front crossmember?
AUIII Straight LPG
Old 21-08-2010, 12:51 AM   #7
Day-mow
rexnet
Day-mow's Avatar
i dont believe so. depending on how big your jack ahhh holder thing (the part that actually is in contact with the car) might fit over both of it. or might fit inside of it.
i think also something else that needs to be commented on is make sure the surface your jacking up on is solid and not going to move. dirt is a no no. concrete is best. and becarful of paving
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Remember it is the internet,So beware of trolls, If you argue with trolls the kids will laugh at you
Follow me on twitter @ Day_mow
Day-mow is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2010, 01:57 AM   #8
mik
mik's Avatar
and just to add, watch that the wheels of the jack don`t get caught on anything , a crack i n the cement ,a tool etc or you might have some thing fall , ie the car off the jack or off the stands at the other end, use caution many people have died from being crushed by cars doing exactly what you are about to do.
Old 21-08-2010, 03:15 AM   #9
atomiclord
atomiclord's Avatar
Check. Should I stack bricks or something under the rear axle for safety? Or is that more of a long-term jacking solution?
There should probably be a 'useful post' link for jacking safely.
AUIII Straight LPG
Old 21-08-2010, 03:46 AM   #10
Day-mow
rexnet
Day-mow's Avatar
tyres are generally used to under the car. bricks i think you'll find will crack
Old 21-08-2010, 04:34 AM   #11
JC
JC's Avatar
Live axle - jack under the diff. At the front, jack under the cross member.
Ford Performance Club ACT
Old 21-08-2010, 12:49 PM   #12
blownv8au
Pro Street Au Ute
blownv8au's Avatar
on the back i use the diff housing or diff center. Front i use lower control arms, i never use the front crossmember but i will not use the sill points as per manufacture description as i've had them cave in on my first xd and have seen other people do it even after telling the what happened to me. But at the end of the day each to their own.
Old 21-08-2010, 03:30 PM   #13
T3man
T3man's Avatar
The diagram is basically correct except for the front alloy cross member. Do not jack by the cross member as I have seen them crack. I jack the front of mine one side at a time using the re-inforced plate behind the front wheel arch.
Old 22-08-2010, 11:58 PM   #14
atomiclord
atomiclord's Avatar
Well, I didn't die, and the car is doing just fine
Thanks guys.
AUIII Straight LPG
Old 22-08-2010, 11:59 PM   #15
KR1STO
KR1STO's Avatar
hahaha
Good to hear mate!!
see my car here:
[SIGPIC][/SIGPIC]
Old 23-08-2010, 09:48 AM   #16
T3man
T3man's Avatar
Thanks guys.
Well don't give up - there's always next time.
Old 23-08-2010, 09:59 AM   #17
galaxy xr8
Giddy up.
galaxy xr8's Avatar
I also use this same point for mine at the front.
