27-08-2010, 03:16 PM | #1 | ||
It seems the torque converter in my XR is constantly locking and unlocking (revs jump up by approximately 150 then back down, up then down etc.) particularly using cruise at highway speeds. At first I thought it may have been a cruise issue but after reading around here I'm convinced it's the converter. Auto was serviced 15000kms ago and the symptoms have been the same since purchasing it in November 2009. Other than that the auto is one the smoothest I've driven.
Any other ideas? Is it a big job? Thanks, Ian
06/01 AUII XR8 |
27-08-2010, 03:21 PM | #2 | ||
The Monty
does it do it with cruise control off? if not id say its ur cruise control doing it not the converter and is a comp problem
27-08-2010, 04:11 PM | #3 | ||
It does do it with cruise off chugging along at a constant speed however it is no where near as noticeable compared with cruise on.. if that makes any sense. When you say a computer problem to do with the cruise control could the cruise control module be faulty?
06/01 AUII XR8 |
27-08-2010, 04:38 PM | #4 | ||
The Monty
if its doing it with and with out cruise its not ur cruise control module, id start by checking if the TB is clean as well as the IAC vavles ports are clean and not damaged
27-08-2010, 05:06 PM | #5 | ||
They're all cleaned regularly mate.
06/01 AUII XR8 |
27-08-2010, 05:29 PM | #6 | ||
There is also a solenoid that controls converter lockup if I remember correctly?
Formerly LV Focus XR5, AU Fairmont Ghia V8 & EBII Fairmont I6. Now...... 2012 FG MK2 XR6 Turbo - Manual & Luxury Pack - 302rwkw 2019 Escape St-Line |
27-08-2010, 05:53 PM | #7 | ||
Just slidin'
My stall converter from TCI done the same thing, i sold it to Stattic, ask him if it strill does it, if not, did h find a reason.
My new Red Diamond one doesnt do it.
MD Mondeo - For the family
27-08-2010, 05:54 PM | #8 | ||
Yep its called the s7 solinoid, if i remember correctly or i could be wrong, its actually in the oil pump it self, so that means gear box will have to come out, if that is found to be the problem or could be the torque converter not working properly
My suggestion is take it to a auto place and get them to hook it up to there computers and get them to have a sticky beak
Welder/Fabricator at Beaudesert Exhuast Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors |
27-08-2010, 07:07 PM | #9 | ||
Just slidin'
It shouldnt be a box problem, like I said, it went away the minute I changed converters.
27-08-2010, 07:29 PM | #10 | ||
yeh but if it is a change of converters job, the box has to be dropped in order for another one to be put in
27-08-2010, 09:24 PM | #11 | ||
Just slidin'
Who the hell said anything about not dropping the transmission?
I have an idea for you. 1. Open thread 2. Read thread 3 Google every word in the thread 4. Write a constructive, and TO THE POINT post 5. Double check it 6. Post it.
27-08-2010, 09:30 PM | #12 | ||
The Monty
settle down boyz.
but very valid point monty |
27-08-2010, 10:15 PM | #13 | |||
27-08-2010, 10:16 PM | #14 | ||
also, i didnt mention anything about changing gear boxes did i, all i said was the box has to come out in order to get to the s solinoid to control lock up or to change converters.
28-08-2010, 06:28 AM | #15 | ||
Just slidin'
I didnt say that you said anything about changing gearboxes Mat. READ what I post before going off on stupid tangents. Make yourself clearer in your posts because noone knows what the hell you are on about 9/10th's of the time, its just random unrelated words strung together with poor spelling and sentence structure.
28-08-2010, 10:31 AM | #16 | ||
Lol @ thread degeneration
I've never noticed any locking and unlocking of the converter during normal driving
Current Blueprint 03 xr8 5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives 256rwkw BA manual Typhoon Fully optioned, 340rwkw@16psi (thanks Bluepower)! The old ride.... AU Fairmont, cammed beast, R.I.P you made my p plate years bearable! 150.8rwkw courtesy BPR |
