03-10-2010, 09:17 PM | #1 | ||
my power steering pump is leaking from the where the hose is screwed into the back the alloy coloured fitting , i have tried to tighten it but its as tight as it will go , and the alloy tube is still loose in the fitting. ????[IMG] Uploaded with ImageShack.us[/IMG]
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak! AU SERIES 3 LIQUID SILVER BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS 123.4 GROUND TEARING RWKW'S , LOL |
03-10-2010, 09:24 PM | #2 | ||
New Hose will probally be in order, same thing happend to my grand fathers ef, cost him like 100 bucks for a new high pressure hose,
Welder/Fabricator at Beaudesert Exhuast Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors |
03-10-2010, 09:46 PM | #3 | ||
Shouldnt it just be the flare?
Should be able to cut it off and reflare it! or the thread has cross threaded. A new hose is a bit excessive just for the fitting Cheers Jason
WANTED: MOMO Metallic blue steering wheel and Manual gearknob! PM Please!!
Stevo _____________________________________ 05/2000 AUII XR6 5sp|Pacemaker 4480 Competition Headers|Lukey catback|Tickford Azzuro's|Impco LPG Conversion |
03-10-2010, 09:48 PM | #4 | ||
Rob
I had the same thing. Ford said it will be a new hose and fitting.. ended up having to pay for a whole new pump.. wasn't to happy. But had to be done.
99 liquid silver AU Classic -Sold
Supercharged Nissan 350z 280rwkw Blueprint series 3 AU V8 manual |
03-10-2010, 09:58 PM | #5 | ||
Big Member
Yes a new hose Maybe in order. Or maybe you can get Pitrek or Enzed to reco it. Not sure if there is one in that section but the o-ring/seal could be perished. Had a similar problem on my beast.
The Scarlet Fairlane: 94 5.Slow Litre NC II Fairlane 488800kms & Climbing Rollin' on genuine ELGT wheels. K&N Filter /////Alpine Sound. EBGT Momo Woodgrain Steering Wheel The Scarlet Fairlane Build Thread Project "White Knight" 93 ED XR6 ROH Alloys Momo wheel Cruise Sunroof Premo Sound Manual HO Goodies PWK Build Thread 1990 Yamaha FZR 250: 59000ks & climbing. New fairing, old tank, my angry mosquito in a coffee tin! 14.977 1/4mile. |
03-10-2010, 10:35 PM | #6 | |||
03-10-2010, 11:00 PM | #7 | ||
found brand new high pressure hoses on ebay for $0.99 all positive feedback for the same items ? ? ? ? not sure though
http://cgi.ebay.com.au/ws/eBayISAPI....#ht_563wt_1137
04-10-2010, 07:52 AM | #8 | ||
Cruising...
x2 for O ring, i had the same thing happen a while ago, dont recall if it was from the high pressure fitting thats pictured above but its usually the seal that goes first so get it checked before anyone decides to replace the whole thing which costs alot more.
FBT '98 BA XT '04 F100 4x4 '82 Subaru Outback '02 Last edited by TheInterceptor; 04-10-2010 at 08:02 AM. |
04-10-2010, 09:51 AM | #9 | ||
If you got the time and the tools and are very careful you can cut the old fitting off and just buy the new fitting from ford spares. All I did for mine (v8, but has same fitting) was make a cut down the length of the fitting using a cutting disc on a 90 degree die grinder. Then all you need is a cold chisel and a hammer to crack the fitting off and fit the new one. Saved me having to remove one bloody big pipe in my case, but seeing as it's on an I6 it's fairly easy to remove the hose to do the job.
Wes
White MY04 Subaru Impreza WRX Hatch - Stock, airbox resonator mod, lowered on king springs Marine Blue EBII XR8 - GT40p's, Paceys, 3in mandrel bent exhaust, Explorer Manifold, YT 1.72 RR's, 65mm TB, 75mm MAF, Thermo's...now manual 1967 Ford Futura coupe 289 C4 stock cruiser
04-10-2010, 03:43 PM | #10 | ||
Be carefull about fluid in the alternator............they dont like it. Do it soon.
AZZA
1967 XR Falcon Wagon, Super Pursuit…….for now. *****XR PARTS WANTED******* |
04-10-2010, 07:13 PM | #11 | |||
Have you got a part number for the fitting to suit the V8? Have the same issue. Sorry to hijack the thread. Ian
06/01 AUII XR8 |
04-10-2010, 10:16 PM | #12 | ||
Not sure off the top of my head, I'll check and shoot you a PM tomorrow.
Wes
04-10-2010, 11:14 PM | #13 | ||
JCTO AUII Falcon
Same problem I had.......needed a new hose and about 3 weeks after a new alternator......alternators dont like the fluid at all......
05-10-2010, 10:22 AM | #14 | ||
Walking with God
I agree it's most likely the O-ring. It's a standard AU thing really. It'll happen sometime! LOL!
As for the alternator, mine in the SR died from the fluid. Someone here a while back though, said they took theirs off after it was being bathed in PS fluid, hot washed it, dried it, put it back on and voila, all good again! All the best with it, but as others have said, better get onto it quickly. GK
05-10-2010, 05:44 PM | #15 | |||
Former BTIKD
05-10-2010, 07:22 PM | #16 | |||
All Bran = Regular Member
I did mine over 12 months ago (it's still going) and my brother did the same thing just recently. His alt stopped charging so he removed, sprayed a can of degreaser into it, washed out with hose, blew out with compressed air and (as you say) "voila". |
05-10-2010, 07:40 PM | #17 | |||
Walking with God
Not 1, but 2 cases of it being successful! GK
05-10-2010, 07:51 PM | #18 | ||
Just slidin'
I cant even see mine from the mixture of P/S fluid and oil. I do spray a can of degreaser down that way every service to keep it all in check though.....
MD Mondeo - For the family
05-10-2010, 07:56 PM | #19 | ||
If it ain't broke........
Aftermarket hoses from places like repco are really cheap for AU series 1 and 2. Wouldn't waste my time at Enzed or Pirtek. Normally these 2 companies only replace the hose and reuse your existing ends.............
Visitors welcome Relatives by appointment only |
