08-11-2010, 08:32 PM | #1 | ||
app diesel mechanic
hey guys, for the past few weeks my au seems to be revving a bit high on the road. when i drive up a hill and it kicks down it revs to 1800-1900 revs which is fine, whats bothering me is when i get over the hill, and the roads nice and flat i take my foot off to bring the revs down or for it to change into 4th again the revs pick up at 1800-1900. on other occasions the revs pick up at 1500 which it usually sits at. sometimes to get it to 90kms from around 85kms it does the same thing which seems really strange for it to kick down just to gain 5km/h more details: it isnt forced kickdown it's the cars natural kickdown.
: im a p plater so i dont know if it does it above 90km/h : the transmission is in full power mode ( economy button off) is this normal? i read in a similar post that it could be a solenoid or some sort of overdrive lock? any helps appreciated, cheers,josh.
daily driver: au series 1.5 forte sedan mods: clarion head unit, 15" alloys, ex police sump guard, futura grill,clear side flashers, AU s2 tailights,BA xr6 spoiler, kenwood 12" sub, kenwood 250W amp, kings sports lows, 2.5" lukey catback. mods to come: rims!! |
08-11-2010, 09:32 PM | #2 | ||
Econ mod off, cause it to rev out longer in the gears,
Econ mode on, causes the converter to lock up much earlier, use this mode when on the high way etc, Either the solinoids on the side of the box is playing up, or the torque converter isnt working properly or locking up To get to the solinoid for the converter lock up is a gear box out job, the other solinoids are done with the transmisson still in the car, Best to take it to a gear box place and get them to test the operation of the box
Welder/Fabricator at Beaudesert Exhuast Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors |
08-11-2010, 09:42 PM | #3 | ||
app diesel mechanic
so there is a genuine issue here? can i drive it the way it is without risking further damage to the box? i have no idea when the box was last serviced so i'm thinking of getting it serviced. would this help? i live down a really muddy dirt road and when i put my sump guard on last weekend, i noticed theres a lot of mud everywhere but there is a fair bit around the transmission and the electrics off the passenger side of the box. ill get under there clean it and see if it makes a difference.
08-11-2010, 09:46 PM | #4 | ||
Maybe pull the connectors out from the gear box and give the contacts a good clean, also get the service done as well
09-11-2010, 01:37 AM | #5 | ||
if last service is unknown getting it done might be money well spent imo.
09-11-2010, 04:26 PM | #6 | ||
app diesel mechanic
im gunna get it seviced january next year, after rego. (money's tight). and it didnt play up at all today. the connectors would be the white blocks on the passenger side of the gearbox? and will disconnecting them make it the gearbox run rough? like, does it have to re learn all it's changing times? that happened when we disconnected the battery to charge it for a few days in dad's el. took 2 days for it to change smoothly and at the right times.
09-11-2010, 05:47 PM | #7 | ||
Changing the fluid makes a HUGE difference if its getting old. Could fix the problem completely. Waiting till january is too long if the fluid is old, hot days coming (hot fluid) will make it worse.
