just woundering if an auto xr6 ecu will be any benifit over my auto standard ef one and will it matter if its an el xr6 ecu
AU FAIRLAINE GHIA TICKFORD I6, KINGS SL/KYB ALL ROUND, RED BACK EXHAUST, G220 RIMS |
they have better idle and better air/fuel ratios i beilive
2015 FGX XR8 - 557rwkw on E85 KPM Street Fighter PCMTec Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19 Shockworks Coilovers PITLANE AUTOMOTIVE & PERFORMANCE
thanks, now i jst need to know if an el xr6 ecu will be ok for a ef gli
No it won't work. The EL has a distributor ignition system, and the EF has a coil pack.
1998 Ford Fairlane - 4.0L
18x8 RJR rims - Tinted - King Suspension - 2.5" D&T Cat Back Exhaust |
ok thanks for that
XRWANAB
i noticed a def improvement in mine with an EF XR ECU over the stock ECU - gave me my idle back, better response with the more aggressive shift points - so def worth it if you've got a few mods! ;)
'95 EF MkII Futura: http://www.cardomain.com/ride/980413/1 |
TL40 Wagon?
Youv'e seen the ECU on ebay right?
It won't fit anything except for EL which runs a distributor not a coilpack. if you can get an EF XR6 ECU then its worthwhile if you don't pay too much. You could of course get a Chiptorque for $600 too brand new and its custom programmable. |
Are chiptorques only $600? Far out. Worth the change?
Viper FG XR6 Turbo
are the XR6 ecu's the same as the fairmont ghia's?
#10 | |||
XRWANAB
although i *think* there are slight differences between the XR & Ghia ECU, although they are both Tickford ones :-S
