Go Back   Australian Ford Forums > Ford Australia Vehicles > Small and Mid Sized Cars > Cougar and Probe
Old 15-12-2010, 05:00 PM   #1
thearrow
Default Someone Should Buy This
Someone should seriously consider buying this.....
http://cgi.ebay.com.au/Ford-Mondeo-C...item230bc70ab9
I would but I already have one
Owning a Cougar is like owning a Super Model
Good to own but "High Maintenance"
2000 Model Eibach Cougar (Auto) - Now dead & buried
thearrow is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2010, 12:26 AM   #2
XR5-Boy
You mad, bro?
XR5-Boy's Avatar
Yeah def agree. They're a rare and sort after mod. I'd buy it, but you know, kinda went spastic with the buffing cloth and ended up with the XR5 :P
2009 LV Focus XR5 Turbo Performance Blue
SFS 2007 Best Cougar, SFS 2010/2011 Best Focus XR5
XR5-Boy is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2010, 05:14 PM   #3
REDDYZ
REDDYZ's Avatar
Already bought SVT one from US with injectors etc etc. So wouldn't need it. Its definitely worth buying for hassle free performance mod. I dont have speedo cable tough. I hope the existing one would fit.
Ex Cougar - 00' MTX 2.5L (Limited edition Eibach Cougar); Dark Green Tourmaline; Lowered with Eibach tuned suspension from factory; SVT UIM, LIM & Throttle body; Supercat 2.5" dual exhaust with twin pipe quad outlets; Custom headers; Custom coloured instrument cluster; K&N Apollo CAI kit; Calibre oil catch can.
Now driving a Lexus RX 450h. Your guess is correct that I am a family man now.
REDDYZ is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2010, 06:48 PM   #4
scout
Is ther anything else that is required??? I have looked at it but unsure what else would be required or have to be done. Any advise would be great.
Trev
scout is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2010, 07:28 PM   #5
REDDYZ
REDDYZ's Avatar
Make sure nuts and bolts are included. You can use the existing ones but not sure about throttle body. Just confirm with the seller.
Old 17-12-2010, 09:40 AM   #6
thearrow
It sounds like all the right bits are all there however I think A$1000.00 is a bit expensive. The bracket and cable are essential, you can use your existing throttle body if you like as this one will be a lot bigger and you will have trouble fitting the air intake hose (the black hose thing that goes over the throttle body) over the larger throttle body but a K&N cold air intake will fix this and you will be sweet after that.
Offer him A$500.00 and he will probably take it, don't forget you will probably have to pay a mechanic to do the install for you.
It is good modification as it really makes the whole engine bay look a lot better, actual HP gain is not that much maybe 5-10hp but it is worth it.
Old 17-12-2010, 05:24 PM   #7
REDDYZ
REDDYZ's Avatar
yeah, $1000 is way too expensive. I spent A$550 including shipping (from USA) which includes injectors along with railing, all nuts and bolts,(few missing) IACV valve, throttle body, bracket, air intake hose, clamps, 2 gaskets, lower intake manifold, basically everything that sits on the block. Only thing I didn't get is the throttle cable. I think I can buy a new one or may be try and use the existing one. Once I clean both the manifolds, will get the upper intake manifold repainted and then I will fit it. If you are seriously looking for one of these, keep searching on ebay.com instead ebay.com.au and now or later you will definitely find one. Use key words like "SVT manifold" or "SVT upper intake manifold" when you search.
Old 17-12-2010, 09:48 PM   #8
scout
Thanks for the advise. I do look every now and then in the states but getting the complete set up seem a little hard. I was also looking at a cold air intake to add a bit more go.
Trev
Old 21-12-2010, 05:01 PM   #9
thearrow
I noticed he has re-listed this at $900.00, still to high, but I reckon he will take whatever he can get. It is good mod and makes a big difference to the engine bay and it is unusual for someone to offer this sort of thing in Australia.
Old 21-12-2010, 05:14 PM   #10
REDDYZ
REDDYZ's Avatar
Yes, it is still expensive. Whoever buys this should make sure that the black paint is in good condition. Otherwise, it looks awkward. I bought genuine SVT and paint is started to peel off. Waiting to get it repainted.
I just found that the listing has ended but posted in a new ad again.
