03-04-2011, 07:04 PM | #1 | ||
hey guys as the titles says, im having the joys of having the death wobbles whenever im sitting on the freeway at anything over 95km/h
-Its been fitted with some sort of Pedders front spring/Shocker setup (unknown) but the lowest point is probably 80mm and thats from the K-frame/sway bar area -the rear has similar shocks and sits about 110mm from the ground, -Front tyres are showing signs of bad wear with the passenger front having wear on the outside edge, -Right front tyre is fairly good, The steering wheel doesn't seem to shake so its doesnt seem to be an alignment issue, it more feels like the whole car is vibrating at speeds, ive tried it in different gears (auto) and still does it regardless of rev's, it does seem to taper out sometimes which is abit unusual!! -Also i dont know if this is related but during slow/dry steering the front suspension makes sort of like a knocking/snapping noise sometimes but never when im driving?! guessing this will be some sort of worn out link issue -So far the plan of attack is that ive purchased a set of superlow springs for the front to hopefully bring it up to the same level as the rear, -Im getting new tyres fitted, (factory tickford 17 inch rims) -Im also dropping it off to my local mechanic for him to check gearbox mount/engine mounts/ and tail shaft etc, Any idea's on what it could be and if anyone else has been fortunate enough to have there other half be slightly aroused while on the freeway! Any suggestions would be greatly appreciated, Ohh and soon to have pictures up! |
03-04-2011, 07:44 PM | #2 | ||
Decent wheel alignment with a camber kit fitted.
Also, get your bushes in the front end checked out. |
03-04-2011, 07:52 PM | #3 | ||
yeah a camber kit doesnt seem to be fitted, which is strange since its been lowered that much,
and yeah the plan was to get the shop to look over the front to see if anything is worn |
03-04-2011, 08:13 PM | #4 | |||
not here much anymore
2024 F150 XLT
03-04-2011, 09:24 PM | #5 | ||
I had the same problem it's rear wheel balance , in my case it was caused by a buckled rim and a new rim fixed it, but you might just need a balance
[SIGPIC][/SIGPIC]
03-04-2011, 10:04 PM | #6 | |||
Fixing Ford's **** ups
Sorry but the above quoting doesn't add up to me. Shake has nothing to do with alignment, yet tyre wear does. As for camber kit. What's that got to do with outside wear. Lowering a car allows the camber to go more negative, which translates to inside tyre wear. My suggestion. Get new tyres, make sure they're balanced properly and have a wheel alignment done. And forget about a camber kit. You obviously don't need it, because the inside edges aren't wearing. The outsides are.
03-04-2011, 10:29 PM | #7 | ||
yeah the whole tyre wear thing has got me abit puzzled really, why would the outside wear down on one tyre?
but i was thinking it could possibly be a balancing issue, i was going to get them to balance all 4 wheels again and go for a full alignment |
03-04-2011, 11:49 PM | #8 | |||
Without going right into detail and confusing the issue, basically the wear problem relates to it toeing in a little too much. Get a wheel alignment (which will solve the wear problem), rotate the wheels front to rear (which helps flatten out the ones that were on the front) and have the rears balanced and put on the front (which should solve a vibration issue).
04-04-2011, 12:39 AM | #9 | ||
Ok tyre wear is down to alignment, to be properly wheel aligned the bushes need to be in good order, and if the cambers no good, then a camber kit needs to be fitted as well.
Shakes could be buckled wheel, or wheel balance, but to me it sounds like it might be uni joints since you said it fades out some times.
'96 EL Fairmont Ghia 5L |
04-04-2011, 01:04 AM | #10 | |||
the wobbles faded in and out with my car infact the problem described was exactly the same as mine so a rear wheel balance would be a good starting point
[SIGPIC][/SIGPIC]
04-04-2011, 08:57 AM | #11 | ||
thanks for the info guys,
im starting off by getting to new tyres for the front today and getting them all balanced, and then its off to the mechanic to have the new springs fitted and aligned then, but im going to get him to check the bushes etc while its up there! |
04-04-2011, 06:09 PM | #12 | ||
*bit of an update*
well i removed the front springs and replaced them with factory springs, had the rear tyres moved to the front (which were nearly brand new) and had 255/40's fitted to the rear, had it all balanced and aligned, drives heaps nicer but now it feels as though the vibration has moved to the front of the car now?! the tyre shop is thinking its going to be a buckled wheel maybe but they need to look at it some more tomorrow(ran out of time today!) BUT on the positive side, the new tyres look very nice, gives the car a far more aggressive stance on the factory 17's, i will try and get a photo of it up in the next day or so! |
04-04-2011, 06:35 PM | #13 | |||
[SIGPIC][/SIGPIC]
04-04-2011, 07:12 PM | #14 | ||
yeah i will be checking them both out tomorrow to find the culprit, Then the hunt will begin to find either 1 or 2 replacement rims to match!
04-04-2011, 07:35 PM | #15 | |||
I have to ask why would you need a camber kit, if the cambers are no good? AU Falcons were the first in the run, that had plenty of room between the inner guard and the upper control arm mounting bracket to be able to shim to correct camber issues. I personally have been able to get 1 1/2 degrees adjustment without the necessity of a camber kit. Then we can add in, the OP had an outer edge wear issue. Lowering a car causes the wheel to lean outwards at the bottom (inwards at the top), therefore causing the tyre to run on the inside edge more. Running on the inside edge is then self explanatary as to the wear you'll receive, which is opposite to what the Op is experiencing. So I really do look forward to a reason behind these comments
04-04-2011, 07:44 PM | #16 | ||
yeah we had a look at adding the camber kit etc to it with the springs fitted to it and it didnt need it, it just needed a proper alignment, but i wasnt happy at how low it sat, so some standard xr springs went in that they had laying around which was handy!
09-04-2011, 09:59 PM | #17 | |||
Fantastic Plastic
HI , with you saying 'the whole car vibrates', it almost sounds like the main driveshaft ( between your dif and tranny ) might be out of balance !. Might even have a worn out universal joint on either end of it too. cheers.
09-04-2011, 11:15 PM | #18 | ||
rexnet
uni joint?
10-04-2011, 01:13 AM | #19 | |||
[SIGPIC][/SIGPIC]
