Old 10-04-2011, 09:10 AM   #1
danxr8
danxr8's Avatar
Default AU111 XR8 Brakes
Morning all,
Today I was replacing front pads in my series 3 xr8 and found that the pads that I had (DB1353) as listed for au3 tickford didnt fit the calipers.Further inspection on the removed pads I found part no DB1375.Cross referencing this no. on the Bendix web site I found out that these pads fit au2/3 utes.Having just bought this vehicle and not being sure of its history I can only assume that theses calipers have been changed at one point OR where fitted as an upgrade(or downgrade) at time of purchase.Is there any kind people out there that maybe able to shed some light.
danxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2011, 10:29 AM   #2
b2tf
not here much anymore
b2tf's Avatar
Default Re: AU111 XR8 Brakes
What size diameter are your rotors? There were 2 brake packs available - standard is 287mm rotor and upgrade is 322mm. From memory the DB1353 is to suit the 322mm upgrade.
2024 F150 XLT
Old 10-04-2011, 10:46 AM   #3
danxr8
danxr8's Avatar
Right o, Have replaced these with slotted rotors but diameter is standard 287mm.Calipers are PBR.
Many thanks for your reply.
