Old 10-04-2011, 01:58 PM   #1
BlueBear
Shockwave
BlueBear's Avatar
Default Factory CD player interchangeable?
Can anyone tell me if it's possible to fit a series III or II factory 6 stacker into a series I?
Have done a couple of searches, but cant see an answer.
Currently have a daggy head unit in it and want to put a stacker in instead.
Can get a series III, but will it fit straight in?
Thanx,
BlueBear is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2011, 04:33 PM   #2
Ford Falcon XR6
Ford Falcon XR6's Avatar
Default Re: Factory CD player interchangeable?
I think it will fit straight in but your steering wheel controls will not work
Ford Falcon XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2011, 05:02 PM   #3
BlueBear
Shockwave
BlueBear's Avatar
So the steering wheel controls will only work with a series I stacker (in my series I AU)?
Might have to look for the correct unit them.
Thanx,
Old 10-04-2011, 06:52 PM   #4
smoo
smoo's Avatar
Pretty sure the Series 2 and 3 units are longer/sit deeper in the dash.
smoo is online now   Reply With Quote Multi-Quote with this Post
Old 10-04-2011, 06:56 PM   #5
T3man
T3man's Avatar
Series II or III will not fit into AU without some hacking; but it can be done if you are determined (and patient).
Old 10-04-2011, 06:56 PM   #6
BlueBear
Shockwave
BlueBear's Avatar
OK Thanx Smoo & T3man.
I guess that seals it then, have to find a correct series I.
Cheers,
Old 10-04-2011, 08:37 PM   #7
FGII-XR6
FGII-XR6's Avatar
IF you have a series one cluster in a series 2 the volume goes up to full as soon as you turn it on smoething to do with the steering wheel controls and the speed alert. so I assume you will get the same problem if you put a S2 stacker in a S1
[SIGPIC][/SIGPIC]
Rides:
