Old 19-03-2011, 11:18 AM   #31
FGII-XR6
FGII-XR6's Avatar
Default Re: Some Unwelcome Symptoms
Originally Posted by Mechan1k
I think Joe said his 4.5L engine is ready to go now from my understanding.
Don't go to FordPro to do a conversion ... I don't trust them ... neither for a few others on here as well. I might get the odd part I can't from anywhere else ... but that's all.
Have a chat with Joe about it.
they did a good job for me
[SIGPIC][/SIGPIC]
Rides:
Old 31-03-2011, 12:29 AM   #32
sly
Sly like a G6
sly's Avatar
Originally Posted by bodes-sh
as for the conversion options, being that yours is a s1 (or 1.5 as you have it), unless you have a s2 front end on it (or high series 1) you will need to do that if you went the ba/f motor and box route as it won't fit under the au1 / xr type bonnet...
By how much does it fail to fit? Joe is doing a DOHC retrofit to an EF XR6 which apparently has a low bonnet as well. It just rubs on the underbonnet rib ATM and he expects to get the motor another 5-10mm lower by modifying the mounts. He thinks it will go in mine, but then he's mainly doing E-series. Mine would be the first AU he's done if I go that way.
There are also issues apparently with adapting up the BA shifter to go into the AU. Maybe I should go manual as well?
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring.
Sleeper, anyone?
sly is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2011, 12:42 AM   #33
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
i've put a BA shifter into an AU... the complete assembly is in there..
its just hard to make it fit really...
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2011, 08:05 PM   #34
bodes-sh
from memory in the thread that ftg auto salvage did when they put the motor in, they cut 1 rib away under the high series bonnet and it fitted without issues. i think that was with standard mounts though, so with lowered ones you may be ok. i think the main problem is with how far forward the motor sits...
i found the thread, but they didn't actually say what series au they used... so that being the case, it may well fit with a s1 / xr bonnet
http://fordforums.com.au/showthread....+motor+into+au
bodes-sh is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2011, 08:25 PM   #35
Stav
Smile
Stav's Avatar
The white specs on plug one look like detonation but its a bit hard to see in that photo.
Stingray Car Security ph 0414445444
Single din radio fascias for fg to fgx fords Australia wide .
FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/
Site Sponsor See Sponsor Stingray Car Security 😍👌✌
AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again
Old 09-04-2011, 09:19 AM   #36
sly
Sly like a G6
sly's Avatar
Yeah sometimes it gives a very faint rattle at higher revs on hot days. Hard to tell whether it's detonation or something else. If I were keeping the engine I'd be playing with the temperature compensation on the timing curve.
But after a few chats with Joe from CMS and a couple of wreckers, it looks like a heart transplant is starting to take shape. Early days yet, more details as things progress...
Sleeper, anyone?
Old 11-04-2011, 07:30 AM   #37
Mechan1k
Mechan1k's Avatar
So what are you going to do now ... twin-cam????
I know he's playing with a B-series engine transplant into an E-series at the moment .... and that should all be sorted for a drive-in drive-out conversion.
Old 12-04-2011, 10:26 PM   #38
sly
Sly like a G6
sly's Avatar
He has 4 E-series lined up for that conversion, NA twin-cam bolted up to the existing 4-speed auto. I'll be going a bit further...
Sleeper, anyone?
