Old 27-04-2011, 04:54 PM   #1
FocusTDCI
Default Focus 2007 TDCI - C1141 Error Code
Hi,
Yesterday my Ford Focus 2007 TDCI had the ABS warning lights come on and report the error message "ESP system fault" on the dash.
I took it to the mechanic today who hooked it up to the computer and it came back with error code - C1141 which is a "Wheel Speed Sensor LF Tone Ring Tooth Missing Fault". They switched the sensors in the wheel over to the other side, took it for a drive and the same fault code came up. They said they will have to replace the housing or something like that.
Does this make sense? Anyone ever heard of this problem before?
Appreciate the help.
FocusTDCI is offline   Reply With Quote Multi-Quote with this Post
Old 27-04-2011, 07:07 PM   #2
marg99
Default Re: Focus 2007 TDCI - C1141 Error Code
The most common cause is bearing failure in the front hub which allows the ABS sensor to misread from the sender on the hub. The loose bearing allows non uniform gap between the sensor and the unit on the hub. Have not heard of the unit loosing teeth but may do so if the hub is very loose. This should show up as sideways movement of the front wheel when jacked up.
