Old 05-07-2011, 11:47 PM   #1
Cadge
Default Engine rebuild kits
Anyone know if they are out there for AUs? And didmt how much they cost? Also, while dling the rebuild, what else should I look at doing?
AUI Ford Fairmont | Lowered with Kings | XR8 Leather Interior | XR6 Tickford Engine and Gear box|
Cadge is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2011, 08:31 AM   #2
FGII-XR6
FGII-XR6's Avatar
Default Re: Engine rebuild kits
I think ACL do a re ring kit for the AU but not a full rebuild kit with pistons
[SIGPIC][/SIGPIC]
Rides:
Old 06-07-2011, 12:01 PM   #3
FGII-XR6
FGII-XR6's Avatar
just checked ACL don't do the kit for the AU here are the various part numbers you will need
Full Gasket Set
GR525MT
Piston Ring Set
C1903Mahle or C9128
C9128 is a high performance ring set suit the 9414S piston.ACL Race Series
Main Bearing Set
7M2092 O/S: STD, 001, 010, 020, 030, 040ACL Duraglide7M2092H O/S: STD, 001, 010, 020ACL Race Series
7M2092HXO/S: STDACL Race Series
Conrod Bearing Set
6B2150 O/S: STD, 001, 010, 020, 030, 040ACL Duraglide
6B2150H O/S: STD, 001, 010, 020ACL Race Series
6B2150HX 0.001" extra oil clearance on STD journal. O/S: STDACL Race Series
Piston Assembly Set
6MKRY4002Mahle
6MKRY9414S a high compression piston kit which can be used for LPG conversions or performance applications with the following indicative compression ratio: 10.2:1 @ 73.4cc total clearance volume. ACL Race Series
6MKRY9414S would be a good option if you were prepared to use 98RON fuel and / or LPG
for a full listing go here http://catalog.acl.com.au/aclwebcata...ttype=0&pg=all
of course machining would be needed too. good luck
[SIGPIC][/SIGPIC]
Rides:
Old 06-07-2011, 12:33 PM   #4
Cadge
Cheers mate
Old 06-07-2011, 09:01 PM   #5
Beer Baron
Gem engines do exchange rebuilt motors but stockers only i think.
AU XLS.
Beer Baron is offline   Reply With Quote Multi-Quote with this Post
