Old 30-08-2011, 06:40 PM   #1
Windsor342ci
The Experience...
Windsor342ci's Avatar
Default Exactly, what is a stall converter?
Hi guys,
Now please forgive me as this may seem a pretty known thing, but in laymans terms, what is a stall converter? Google likes to think Im a mechanic and I understand the lingo...
So exactly, what it is? What does it do? What are the pro's and con's about it?
Mods - Forgive me if this is in the wrong area and please move if need be but once you've stopped laughing at me I’m sure you'd be able to see that I genuinely don’t know the best area for it as I've got no real idea what the bloody thing is.
Thanks in advance guys.
Her Daily: BF XR6T ZF
His Daily: FGX XR8 ZF
Their Pride: T3 TE50 Manual
Windsor342ci is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2011, 06:45 PM   #2
Geez Louise
Awesome
Geez Louise's Avatar
Location: In my own little world..Everyone here knows me :)
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: All the behind the scenes things that help the community.
Default Re: Exactly, what is a stall converter?
From my understanding it is basically like a clutch for an automatic transmission...I could be wrong though so would love to know if I got that right myself!!
Geez Louise is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2011, 06:53 PM   #3
Avanti
Yeah I gathered the same answer myself? maybe your onto something?
from my understanding, the higher the stall, the higher revs the 'clutch' goes in
Avanti is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2011, 06:54 PM   #4
ILLaViTaR
ILLaViTaR's Avatar
I've also wondered this, I know what it does but is it just another name for a torque converter or a different part entirely? It allows you to rev the car up a lot higher in gear than you would normally.
EB II 1992 Fairmont - koni reds, wade 977b, 2.5inch/4480's and much more to come!
ILLaViTaR is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2011, 06:58 PM   #5
vanman_75
XD Sundowner
vanman_75's Avatar
Not that silly a question ,Louis got it right its the link between engine and trans / gearbox .with varying stages of when they " lock up " as to a clutch slipping in a manual gearbox ( basically)benefit is no clutch no need to change gears , allowing a auto box to be in place instead . There are many benefits if you only got 1 peg ...but I like my manuals , for no other reason , just because .no doubt people will fill you in more..since seen the answers yes one and the same
something old something blue
vanman_75 is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2011, 07:00 PM   #6
Road Games
Road Games's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Replacement.
Cool Torque Converter Operation...
The torque converter is one of the least understood components in an automatic transmission equipped vehicle. I will attempt to explain what it does and how it does it.
Torque Converter Basics
The torque converter has a few different functions.
We first need to understand that there is no direct link between the crankshaft and the transmission input shaft (except in the case of a lock up style converter, but we'll talk about that later). This means that the first function of the converter is to connect the crank and the input shaft so the engine can move the vehicle, this is accomplished through the use of a fluidic coupling effect.
The torque converter also replaces the clutch that is required in a manual transmission, this is how an automatic transmission vehicle can come to a stop while still being in gear without stalling the engine.
The torque converter also acts as a torque multiplier, or extra gear ratio, to help the car get moving from a stop. In modern day converters this theoretical ratio is anywhere between 2:1 and 3:1.
Torque converters consist of 4 major components that we need to concern ourselves with for the purpose of explanation.
The first component which is the driving member, is called the impeller or "pump". It is connected directly to the inside of the converter housing and because the converter is bolted to the flexplate, it is moving anytime that the engine moves.
The next component is the output or driven member and is called the turbine. The transmission's input shaft is splined to it. The turbine is not physically connected to the to the converter housing and can rotate completely independently of it.
The third component is the stator assembly, its function is to redirect the flow of fluid between the impeller and the turbine, which gives the torque multiplication effect from a standstill.
The last component is the lock up clutch. At highway speeds this clutch can be applied and will provide a direct mechanical link between the crankshaft and input shaft, which will result in 100% efficiency between the engine and trans. The application of this clutch is usually controlled by the vehicle's computer activating a solenoid in the transmission.
Here's how it all works. For the sake of simplicity, I will use the common analogy of two fans which represent the impeller and the turbine. Let's say that we have two fans facing each other and we turn one of them on, the other fan will soon begin to move. Thefirstfan,which is powered, can be thought of as the impeller that is connected to the converter housing. The second fan- the "driven" fan can be likened to the turbine, which has the input shaft splined to it. If you were to hold the non-powered fan (the turbine) the powered one (the impeller) would still be able to move- this explains how you can pull to a stop with your automatic without the engine stalling.
Now imagine a third component placed in between the two which would serve to alter the airflow and cause the powered fan to be able to drive the non-powered fan with a reduction of speed- but an increase of force. This is essentially what the stator does.
At a certain point (usually around 30-40 mph), the same speed can be reached between impeller and the turbine. The stator, which is attached to a one way clutch, will begin to turn in conjunction with the other components and around 90% efficiency between the crank and the input shaft is achieved. The rpm at which this occurs under full throttle is often referred to as "stall speed".
The remainder of the slippage between the engine and trans can be eliminated by connecting the input shaft to the crankshaft through the application of the lock up clutch that was mentioned before. This will tend to lug the engine, so the computer will only command this in higher gears and at highway speeds when there is very little engine load present. The main function of this is to increase fuel efficiency and reduce the amount of heat that is generated by the converter.
High Stall Converters
A high stall converter differs from a stock converter in the sense that the rpm is raised at which the internal converter components- the impeller, the stator and the turbine start to turn together, and hence, stop the torque multiplication phase and begin the coupling phase.
The idea behind a higher stall converter is to allow the engine to rev more freely up to the point where the powerband begins, and therefore, enable it accelerate from a stop under more power.
This becomes increasingly important when an engine is modified. Engine mods such as ported heads, bigger cams, bigger turbos (in some cases), bigger intakes, etc. tend to raise the point where the powerband begins. For best performance, the stall speed needs to be raised accordingly to work optimally in conjunction with the given vehicle alterations.
In simple terms, for best performance, the stall speed should be raised at least to the point where the torque curve is heading for it's peak. As a rule of thumb, the stall speed should be set to match the rpm at which the engine is making at least 80% of it's peak torque for a street driven vehicle.
As you can imagine, a vehicle that can accelerate from a stop with 80% of its peak torque will easily outperform the same vehicle that can only launch at 50% of its available torque.
I hope this helped to explain a relatively simple device that has a complex set of functions.
-John
John Lombardo
IPT Performance Transmissions
973.827.9946
http://www.ipttrans.com
Road Games is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2011, 07:29 PM   #7
vanman_75
XD Sundowner
vanman_75's Avatar
Above is why I didn't type no more , knew someone had time on their hands
Old 30-08-2011, 07:32 PM   #8
Road Games
Road Games's Avatar
Everything is available mate .. just gotta know where to look
Old 30-08-2011, 07:38 PM   #9
Geez Louise
Awesome
Thanks for the explainations guys.
I find it hard sometimes to explain something, when you know what it is there for but not 100% sure if you are right.
Didn't want to seem like a fewl!
Old 30-08-2011, 08:16 PM   #10
Windsor342ci
The Experience...
Thanks John. Well explained! And I understood!!!
