mr xagt
hey guys,i had a experience today with byrne ford service,been having a few issues with my AU2 xr8,the car is cutting out and felling like its running out of fuel, so i thought id get ford too look at the car as ive had no joy with a few other mechanics.
anyhow they said it took 3.7n hrs labour at a cost of $396.00 too put a scan tool on the car and diagnose it was the o2 sensors that needed replacing?problem is the car still not fixed and im feeling rather ripped off as i think its rather expensive.do i have any avenue too take with them over this? just looking for opinions i guess,cheers jas |
So the only work done was a scantool reading and oem sensors used as a replacemant,am I correct?
Was there any other time spent looking at other areas manually looking for issues? |
Yeah id be complaining. If they did not do anything else they have added like a 2 hour lunch break in there.
mr xagt
scaned it,then cleared the codes,dont even think they took it for a test drive
Tickford 220kw Windsor...
You took it to a Ford dealer = Nuff said.. Forget going back, just find a decent EFI workshop that can troubleshoot your car properly.
There can be a lot of diffrent things that cause the problems your describing. The Oxygen sensors are usually the first and easiest part to replace to see if that quick fixes it. Sometimes thats all it takes, but in my experience it usually takes more digging to find the true problem... These kinda faults can lead to checking over quite a bit of the efi system, so you really need someone who understands how efi actually works, not some "supposed tech" from Ford who cant do much more than only reads and clear fault codes..
1972 Falcon XY GT 351 Clevo 4V Big Port, 4 Speed Top Loader Manual, Ice Blue.... 2002 Tickford AU Series III XR8 220kw Windsor, 5 Speed Manual, Liquid Silver... __________________ AU Tickford Facebook fan page.. https://www.facebook.com/#!/home.php...25060040851023
spoolin!
so they diagnose you car... find the problem... advise you what to do... because other mechanics couldn't find the problem?
And also you think as simple as just plugging the scan tool in? You dont think or know if they took it for a test run? So pretty much you are just speculating that they didn't. Did you ask?
Current Ride - 2016 FG-X Falcon XR6 Turbo Manual. Smoke Grey Previous Rides - 2014 Black Mica PX XLT Ranger Dual Cab 3.2 Diesel 2011 FPV GS 315 Sedan. Sunburst, manual, fully optioned. Build #165. My 1955 Ford Thunderbird Project (A tribute to my late mother) - 1955 Thunderbird Build Thread
You just learned a $396 lesson
seem to get more complaints from Queensland dealers than anywhere else for some reason, so it was running like a pos when you left the dealer??
mr xagt
car only plays up under acceloration,idles fine,and if you drive it real easy its ok aswell,but when you put it under load its like its running out of fuel,if you shut it down and start it again while coasting it fine again
Sling Shot
Replace your leads and plugs mate
mr xagt
hi,ive replaced leads,plugs,crank sensor,harmonic balancer,fuel filter,cleaned tb and afm.
#12 | ||
mr xagt
what also i thought was rude was they quoted me $280ea for a genuine o2 sensor,$150ea for a non genuine,which they get from bursons,and i rang bursons up and got them for $82ea lol
#13 | |||
If they charged you $396 because they "fixed" your problem, can't you go back and get them to do it again for free, because they never actually fixed it, that would be my argument.
#14 | |||
Current Rides 02 AUIII XR8 97 Kawasaki ZZR1100 2001 Honda VTR1000 SP-1 97 Honda XR400 Stored Projects 64 MK1 GT Cortina 66 Fairlane GT |
#15 | ||
Fuel pump?
Cam syncronizer assembly or the electronic sensor? Ask them if they had a look at any of the above in their 3hr diagnostic "playaround". The cam sync assembly is an easy one to see. Removal of coil packs and the sensor unit is required, then grab the shaft and see if you have excessive movement which opens up the gap between chopper pin and sensor. If gap is to great, sensor cannot read and engine feels like it is running out of fuel as it reads, then doesn't shutting it down, then reads again and fires up again. This process happens until the engine losses power and mobility and shuts down completely (stalls). Hope this helps somewhat. Regardless of the dealership issue, let us know what you find. It may help someone out. Cheers. PS. If it is the cam sync mechanical unit that has to be replaced, ensure you replace the sensor also. Been there, done that. |
#16 | |||
My first thoughts would be fuel pump, or a blockage in the fuel pickup sock. Another place to check is the fuel pressure regulator, that is critical to maintaining the correct fuel pressure in the rail before the excess fuel returns to the tank.. Wrong fuel pressure can result in poor injector spray pattern/volume or too far out of normal pressure limits can stop the injectors opening at all.. When getting fuel pressure checked, make sure the place also checks fuel volume. Iv seen quite a few cases of good fuel pressure, but poor fuel volume..
#17 | ||
mr xagt
ta guys,rang up byrne and spoke too the tech directly and he reckons the car is over fuelling itself,and thats why its is shutting down?so basiclly i have too take it back again and spend more $ on diagnosis.
#18 | |||
Back to Le Frenchy
It's quite obviously a fuelling issue.
Does it do it all the time or only with a 1/4 tank or less? Best bet is to start from the back and work forward. Is the fuel pump ok? Pull it out and inspect, especially the sock and the feed tube. Fuel filter? Did you pick up a batch of bad fuel at some stage? Pull the filter again and check it, easiest way is to put your mouth to the inlet side and blow, there should be very very little resistance. If you did pick up bad fuel you can replace a filter only for the next one to clog with residual left behind. Further forward check all fuel lines under the car, it could be that you drove over something that has flicked up and crushed the lines. If all that is fine and you still have issues then you need to look at the fuel pressure regulator and the injectors.
#19 | ||||||
XR & FPV Owner
Oh wait... Quote:
![]() I've seen issues like this before too. Pump (less than 10%) Leads (20%) Plugs (20%) Foil plug lead insulators (30%) Coil pack (10/20%) One of the most common and overlooked issues I saw was the foil that can short against the headers. Most of the smart Techs would remove it before installing new leads.
2005 BF GT (6sp manual - Build #183) 2015 SZ MkII Territory Titanium 2016.75 LZ Focus Sport Quote:
#20 | ||
mr xagt
well did o2 sensors and fuel reg and still no good,got me stuffed. as soon as you give the car a half a bootfull it shuts down like its over or under fuelling and shuts down.
#21 | ||
dont they have that odd random fuel reg thing that can happen..??
sorry thinking aloud....... ![]() |
#22 | ||
Fuel pump is a known drama. Funny how all the blame is with Ford and not your other mates who cant fix it.
XC GXL Warm 351c AOD ![]() 09 VE SV6 Sportwagon ![]() BA Fairmont Ghia ![]() |
#23 | ||
mr xagt
mmmm.i thought i was doing the right thing by taking the car too ford as they built the car and should have insight too problems that occur with the cars they produce,all i got was a shrug of the sholders and we think this is the problem and give us $400 bucks thank you.
i have no problems paying for a job well done,when its well done? |
#24 | ||||
#25 | |||
![]() Join Date: Dec 2004
#26 | ||
mr xagt
yes,tah, i was planning too, just got the shi.s atm,but thats the next plan of attack
#27 | |||
Force Fed Fords
Fuel regulator. Had an AU2 LTD with the same problem, turned out to be over fueling. Have you noticed heaps of black soot on the rear of the car after you wash it?
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley Quote:
#28 | ||
mr xagt
hi,ive replaced the fuel reg last fri nite and still playing up.
#29 | ||||
Force Fed Fords
MAF sensor?
#30 | ||
So what you are saying is your car has a complex problem that you have no idea how to fix so you take it to several others who spend time diagnosing but still have not found the final answer so you think you should not have to pay them for all the time they spent?
