Old 08-11-2011, 09:20 AM   #1
ynneb/benny
Default Continually replacing stop lights (Fairmont AU )
Hi, I tried to post this in electrical but it seems newbies dont have sufficient permissions. ???
I am needing to replace the stop lights on my AU at least 3 times a year. They continually blow. At one stage I installed some LED ones but over time individual LEDs stopped working, and they also stopped my cruise control from engaging.
I have read in other places that AUs are knowing for blowing rear lights, but I am yet to find out a solution.
It's not that replacing them is a pain, its more that I never know if I am driving around without brake lights until another motorist tells me.
Any Ideas or solutions?
ynneb/benny is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2011, 09:33 AM   #2
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Default Re: Continually replacing stop lights (Fairmont AU )
What kind of globes are you using, are they a cheap set from supercheap/autobarn, etc.
As I was told that the cheap ones will do this time after time, might need to get a better globe from an reputable Auto elec.
Old 08-11-2011, 09:36 AM   #3
Smoke Pursuit
And be careful how you install them.. Dont touch the glass.
2022 RAM Laramie 5.7
2023.50 Ranger Wildtrak 3.0 V6 Premium Pack
2024 Everest Sport 3.0 V6 Touring Pack
2025 Mustang Darkhorse 6M Blue Ember + Appearance pack ETA April 25.
Old 08-11-2011, 09:49 AM   #4
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
nah, they're not. someone's made that up.
how many volts is your alt outputting?
Old 08-11-2011, 09:59 AM   #5
ynneb/benny
Thanks for the responses guys. The globes were Narva brand from memory. I might ask at Repco if they have better quality globes.
Mr Hardware, Without using a multi meter and reading the dash voltage meter, it shows about 14.5 volts. (How accurate are those meters?)
Old 08-11-2011, 10:02 AM   #6
Mr Hardware
i don't trust any of my cluster guages.
get a multi-meter on it.
if you want long-lasting globes get some 'tungsram' ones
Old 08-11-2011, 10:23 AM   #7
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Yeah the dash cluster is just a guide, not totally accurate.
Old 08-11-2011, 10:53 AM   #8
kempy311
BEN
kempy311's Avatar
Maybe caused from slamming the boot to hard.
My Thread. The new whip: 2014 FGX XR8 Auto in victory gold. Mods : BMC air filter, 1500cc injectors, Walbro 485, 58mm kpm snout, kpm intercooler, 35% front and 20% rear tint, pedders supercar coilovers, whiteline sway bars, Phillips HIDs, lenso d1r wheels.
331rwkw.
12.7 sec stock as a rock with a passenger.
Now with 620rwhp ready to run the 10
built zf, built tailshaft, corn juice all to come.
The old rig: 2008 FG XR8 Auto in dash green with a tonne of mods to make 311rwkw.
kempy311 is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2011, 11:34 AM   #9
blueoval
Critical Thinker
blueoval's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Well thought out and constructive posts.  A real credit to this forum.
I found this an issue too in the past, but when I checked my globes they were fine, the terminals weren't in good shape though with visible signs of surface rust as well as the connection of the terminals of the globe being a bit loose too. I cleaned up the terminals and made sure the points of contact were firm and (touch wood) I haven't had an issue since.
"the greatest trick the devil pulled, is convincing the world he doesn't exist"
2022 Mazda CX5 GTSP Turbo
2018 Hyundai Santa Fe Highlander
1967 XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 AU2 75th Anniversary Futura
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2011, 07:12 PM   #10
Jim Goose
Does your car have a tow bar fitted?
Reason i ask is that my old EL wagon would constantly blow the RH rear brake light... eventually i poked around and found that the brake wire for the trailer plug was connected near there. I dissconnected it and it didnt blow a bulb until i reconnected the wire (almost immediately).
You've seen it, you've heard it and your still asking questions??
Don't write off the Goose until you see the box going into the hole....
Jim Goose is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2011, 10:13 PM   #11
v8falconsrule
Blue ~oval~ Blooded!!!
v8falconsrule's Avatar
i used to run the narva brand ones and was constantly blowing lhd brake light globes, switched to motorcraft (part # elb380b) and never replaced one since.
Give me fuel, give me fire!
50th Anniv G6E Turbo in Sensation
Cobalt blue 94 ED XR8 Sprint- resto/ project
v8falconsrule is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2011, 11:11 PM   #12
antisocial
Our AU II Fairmont wagon used to blow drivers side brake lights every few months.
Fixed it by trading it in on a Focus....
antisocial is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2011, 12:40 AM   #13
z80
When you are buying replacement bulbs just be sure that there are at least two filament supports.
Filament supports are the thin wire posts that help suspend the coiled bit that glows white hot.
Cheap bulbs have only the end posts and are susceptible to vibrations when hot.
you might pay a lot more though.
z80 is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2011, 06:54 AM   #14
galaxy xr8
Giddy up.
galaxy xr8's Avatar
I went out and checked mine and what do you know, the driver's side brake light has blown...doh..
Old 09-11-2011, 09:03 AM   #15
ynneb/benny
Interesting ! I replaced the globes today and all the blown ones are Narva. Unfortunately I replaced them with the same brand this time. I will certainly try a different brand next time.
Repco had 3 brands there. The sales person said that Narva was the best. I wonder if they WERE the best, until they started outsourcing to China.
