Old 29-11-2011, 06:24 PM   #1
Day-mow
rexnet
Day-mow's Avatar
Default IRS diff. whose changed one
so my diffs died. im gonna give it a crack on my own. i have access to a hoist which will help. is it an epic job or is it do able? im going to have a 2nd car and so time isn't as much of a restraint as it could be. do i need any special tools?
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Remember it is the internet,So beware of trolls, If you argue with trolls the kids will laugh at you
Follow me on twitter @ Day_mow
Day-mow is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2011, 07:10 PM   #2
Sox
RIP...
Sox's Avatar
Default Re: IRS diff. whose changed one
I did mine about 3 months ago, it's pretty straight forward.
Remove wheels.
Exhaust tail piece.
Tailshaft.
Lower control arm outer bolts.
Pry out CV's from diff.
Diff bolts.
Lower diff while holding out lower control arms.
To fit new diff, do the above in reverse order.
Took me about 4 hours, and I hadn't done one before.
Oval Everywhere...
Old 29-11-2011, 07:16 PM   #3
Whoosha
AU DIE HARD
Whoosha's Avatar
ME
Heres the techo thread
http://www.fordforums.com.au/vbporta...article&id=159
And a bit more here
http://www.fordforums.com.au/showthr...light=IRS+diff
No real problems as Sox says but it s easier with 2 people and if you have all FINGERS and THUMBS in working order
Originally Posted by Riksta
Old 29-11-2011, 10:29 PM   #4
Day-mow
rexnet
Day-mow's Avatar
sweettt!!! i've found a killer diff in sydney from a friend. so i'll get that when i get some $$$ together.
cheers sox n whoosh sounds like it should be alright then. probably can get a spare body to help me out and this time shall try hard to not destroy any digits or such.
Old 30-11-2011, 11:44 PM   #5
Day-mow
rexnet
Day-mow's Avatar
and also. is there anything i should replace while i've got stuff out? any bearings or such.
Old 01-12-2011, 07:28 AM   #6
Sox
RIP...
Sox's Avatar
Not really, check the CV boots, tailshaft unis, but it's probably all ok, otherwise you might have noticed anyway.
Maybe even have a glance at the gearbox extension housing seal.
Oval Everywhere...
Old 01-12-2011, 08:11 AM   #7
Day-mow
rexnet
Day-mow's Avatar
is that the one the yoke of the tailshaft slides into? i noticed it with a very slight leak and thought i'd do it soon.
Old 01-12-2011, 08:19 AM   #8
Sox
RIP...
Sox's Avatar
Yep, change it.
Takes all of 5 minutes, and $10 or so.
Oval Everywhere...
Old 05-12-2011, 03:19 PM   #9
Day-mow
rexnet
Day-mow's Avatar
Sic will do that. Did you need any special tools?
Old 05-12-2011, 04:35 PM   #10
blueoval
Critical Thinker
blueoval's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Well thought out and constructive posts.  A real credit to this forum.
I doubt it special tools will be needed. Just a time consuming job to do and no doubt a heavy one. Just don't rush the job, and check and recheck everything once the new one is in. You may need to refer to the manual for torque settings of some things, but should be straight forward.
"the greatest trick the devil pulled, is convincing the world he doesn't exist"
2022 Mazda CX5 GTSP Turbo
2018 Hyundai Santa Fe Highlander
1967 XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 AU2 75th Anniversary Futura
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2011, 05:42 PM   #11
Sox
RIP...
Sox's Avatar
I can't really remember, but I don't think so.
Oval Everywhere...
Old 19-12-2011, 12:25 AM   #12
Day-mow
rexnet
Day-mow's Avatar
What is this ring. Does it need replacing or do I bend it in or what?
Old 19-12-2011, 07:40 AM   #13
Sox
RIP...
Sox's Avatar
Leave it on, doesn't need replacing.
It holds the axles in.
Oval Everywhere...
Old 19-12-2011, 01:48 PM   #14
Day-mow
rexnet
Day-mow's Avatar
Sweet
