Old 22-12-2011, 09:42 AM   #1
raised by monkeys
raised by monkeys's Avatar
Default 5.0 harmonic balancer
G'day guys,
Im confused on which harmonic balancer would be best regarding quality/price. It looks as though the spacer (?) behind the pulley is out of whack. Any help appreciated.
cheers
Shaun
Current
SY FPV F6X Territory #214
Previous
FG MkII G6E Turbo built by Heinrichs Performance and Tuning
BFII FPV TORNADO #0021 351rwkw - Heinrich Performance and Tuning
"Milk is for babies. When you grow up you have to drink beer" - Arnold Schwarzenegger
raised by monkeys is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2011, 10:11 AM   #2
b2tf
not here much anymore
b2tf's Avatar
Default Re: 5.0 harmonic balancer
Unsure on brands but be careful what you buy as the AU one is different to other ones. I think it may also be different on the Tickford (XR) motors as opposed to the non-XR models too.
2024 F150 XLT
Old 22-12-2011, 12:55 PM   #3
crakrz
T3 TE50 Blueprint
Technical Contributor: For members who share their technical expertise. - Issue reason: Craig has shown and shared an outstanding amount of knowledge in the field of Tuning. Craig is only to happy to share with anyone that asks his knowledge on the EEC tuning system, in particularly in the use of Moates Quarterhorse and Binary Editor.
What spacer?
crakrz is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2011, 02:04 PM   #4
raised by monkeys
I just a had a quick look to see what varieties popped up on ebay, and the only 5.0 efi ones that i found, that were for the AUS 5.0 suited fairlanes/fairmonts. My initial guess what that they would be the same?? Any thoughts?
Originally Posted by crakrz
What spacer?
There what looks like some sort of rubber spacer behind the pulley which seems to be causing it to spin a little off.
cheers
Shaun
Current
Previous
Old 23-12-2011, 04:19 AM   #5
david256
What happens the Rubber between the inner and outer rings lets go, that's what you'll be seeing.
I think I paid about $220-$240 from Bursons about 2 years ago, if I was purchasing one now I'd go to Rock Auto and get one for about $50 + $90 shipping.
david256 is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2011, 09:27 AM   #6
raised by monkeys
did you buy an aftermarket direct replacement or performance part?
cheers
Shaun
Current
Previous
Old 23-12-2011, 11:42 AM   #7
david256
Aftermarket direct replacement, looks exactly the same as the ebay listing from CarsRUS
http://www.ebay.com.au/itm/Ford-AU-F...item588e41184f
or Rock Auto
http://info.rockauto.com/getimage/ge...94-155-007.jpg
Does your engine feel like its missing or vibrating thats what mine did when the Balancer went.
Old 23-12-2011, 12:03 PM   #8
raised by monkeys
well, the original problem was that i think was the fan belt started squaking, but followed by a bizzare surging. So what ive done is have the fan belt, pulleys, alternator, and water pump replaced (the alternator was on its way out and i was recommended that the water pump starts to corrode from the inside out by the time the car has hit around 150000kms). So everything is off, but noticed that the rubber piece behind the pulley of the harmonic balancer is looking a little worse for wear and rotating a little off, and thought that while everything off it might be an idea to replace that if its on its way out. Although, i need the car going in this next week so i can look at it a bit later down the track. Looking at opening up the motor this coming year, so if it holds out, can do it then.
cheers
Shaun
Current
Previous
Old 23-12-2011, 11:32 PM   #9
irdonn
irdonn's Avatar
Hmmm... squaking and surging... have you looked at the cam synchroniser mate?
06/01 AUII XR8
irdonn is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2011, 06:16 AM   #10
david256
If you can see rubber sticking out from the balancer it is stuffed, basically what happens the rubber lets go between the inner and outer ring and is forced out and the rings spin and becomes unbalanced.
The surging your feeling will be from the balancer, me and a mate spent days trying to find it with my Fairlane, we stripped everything, replaced plugs and leads even the coil packs. And yes its weired.
Can you take a photo of the balancer.
Old 26-12-2011, 12:58 PM   #11
raised by monkeys
im about to pick up my car today from the mechanic. If its still surging it will stay where it is and i will just do the cam synchro and the harmonic balancer
as above.
thanks for the helpfull hints guys.
From my understanding, the cam synchro, in laimans terms, monitors the rotation of the cam? can someone confirm?
can someone explain to me the full operation of the harmonic balancer?
thanks heaps.
cheers
Shaun
Current
Previous
Old 27-12-2011, 01:19 PM   #12
raised by monkeys
Picked up the car yesterday, and it feels as though it is running a lot better, but sometimes when at initial turn over before it is actually fired up, it sounds as though something struggling, maybe the starter??? The water pump was half corroded inside. Good call Peuty
Theres also a bizzare ticking every now and again, however, i hear the windsors are renowned for being a little weazy at times. Glad im getting maintenance done though before mods though, its a great to have the overall feeling of a car improve and makes Bruce (my cars name) a little more trustworthy
cheers
Shaun
Current
Previous
Old 30-12-2011, 08:49 PM   #13
b2tf
b2tf's Avatar
How did you go with the balancer? I just found this:
http://www.ebay.com.au/itm/POWERBOND...item2a0fee0cc9
2024 F150 XLT
Old 31-12-2011, 10:59 AM   #14
raised by monkeys
The car has surged a couple of times but not as bad as before. In the new year when i get a little $$ i'll take the ute to my regular mechanic and have him to have a look at the cam synchroniser and harmonic balancer.
thanks for the link.
cheers
Shaun
Current
Previous
Old 03-01-2012, 07:40 PM   #15
Peuty
Afterburner + skids =
Peuty's Avatar
No problems.
Out of interest, where did you get your pump from? Cost? Brand?
Oo\===/oO
Old 03-01-2012, 08:29 PM   #16
raised by monkeys
http://www.ebay.com.au/itm/160473245...84.m1497.l2649
cheers
Shaun
Current
Previous
Old 04-01-2012, 04:22 AM   #17
david256
Originally Posted by Peuty
No problems.
If your looking for a Water Pump look here $75.00 free shipping and made in USA from a local seller.
http://www.ebay.com.au/itm/180786205...84.m1423.l2649
