Old 19-01-2012, 09:51 PM   #1
shayne93
66 Mustang
shayne93's Avatar
Default Au Ute pulls left, replaced BJs and bushes, still pulls left
My AU3 ute pulled left, i took it for an alignment at fulcrum and was advised that all the bushes and left bottom bj were shot, so you had to hold the steering wheel about 30 degrees right to steer straight on highway. so I replaced all front bushes and ball joints.
Ive taken it to an alignment shop, *such and such* tyre and alignment, on the highway it still pulls agressively left, not as bad but still very bad, but if you have the steering wheel dead ahead, it goes straight ahead, just don't let go of it, or you're in a ditch.
Anyway, do I need a camber kit so the front of the left top control arm can be shimmed to bring the top BJ back? the alignment bloke recons he just cant get enough left pos caster and the bottom ball joint needs to come forward.
I've got a 66 Mustang and tbh, these AU's seem to have the same amount of adjustment as the early mustangs/falcons stock, can only be adjusted from top arm, XY falcons had more adjustment, with top and bottom control arms as well as caster bars.
So anyway, what is my best bet to fix?
shayne93 is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2012, 11:03 PM   #2
T3man
T3man's Avatar
Default Re: Au Ute pulls left, replaced BJs and bushes, still pulls left
What's the full story? Have you just bought it and it's always done it? Or has it just suddenly developed? It is caused by something that has happened slowly or suddenly over a period in time and the more you can tell us the better.
Old 19-01-2012, 11:35 PM   #3
svo supporter
Fixing Ford's **** ups
svo supporter's Avatar
It may be a Caster problem...It maybe a camber problem.....It may be another problem. If you have a report to post, that'd be a good starting point.
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises.
Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here
Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone
Old 20-01-2012, 06:58 AM   #4
shayne93
66 Mustang
shayne93's Avatar
It has always done it since I have had it (8 months).
I asked for the report but apparently their printer was broken, I'm not sure what to think there.
The bloke at the alignment joint recons he just couldn't get enough left positive castor out of it.
Old 20-01-2012, 07:38 AM   #5
The Monty
Just slidin'
The Monty's Avatar
Id say old accident damage, bent stub axle.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 20-01-2012, 07:57 AM   #6
T3man
T3man's Avatar
sounds like it could be ... or bent arms/misaligned frame. Worn ball joints won't cause that severe a pull on the wheel. Also try changing your front wheels from left to right as it may be a badly worn tyre on one side causing it.
Old 20-01-2012, 08:07 AM   #7
shayne93
66 Mustang
shayne93's Avatar
I'll try that, I just had a look and there's at least 10 mill of thread left on the left top control arm thread, but apparently no more adjustment??? Gee, svo supporter's signature is starting to make sence haha :p
Old 20-01-2012, 10:09 AM   #8
shayne93
66 Mustang
shayne93's Avatar
I have swapped the front wheels around, no joy :(
Old 20-01-2012, 07:38 PM   #9
svo supporter
10MM of thread = 1 1/2 degrees of more caster can be added.
Then we can look at the right hand side to reduce caster to help the car drive straight.
So I'll leave it upto you how much the place is pulling your leg about adjustment. (Hint, lazy seems to spring to mind).
Bugger about no report. That'd help me help you immensley.
I quite often find, that because the radius rod has slight bends in them, they straighten out, from parking against the concrete blocks that are located in car parks. When they straighten out, this reduces the caster on the left first(because the lefthand wheel is further forward than the right), therefore creates the drift, or pull that alot of Falcon and Commodore owners experience. IMA, just adding in Commodores, just so people don't think I'm singling out Falcons.
It doesn't necessarily need to be a big wack, but over a period of time, constant bumping of these blocks causes this to occur.
Of course people won't agree with this statement, but I'm putting it out there from my personal experience dealing with these exact issues.
Old 20-01-2012, 08:50 PM   #10
shayne93
66 Mustang
shayne93's Avatar
Maybe I should seek a wheel alignment from Fulcrum. And I wasn't aware these things had radius rods.
Old 20-01-2012, 11:01 PM   #11
svo supporter
Get an alignment where ever you feel comfortable, providing you get a printout. Once you've got a printout, post it and then things might become clearer and I maybe able to help further.
Old 21-01-2012, 08:05 AM   #12
Sox
RIP...
Sox's Avatar
It's pretty hard to agree with you, considering AU's don't have radius rods.
I can't see the the lower control arm bending anytime soon because of bumping into parking blocks.
Though I do agree with the rest of your post.
Oval Everywhere...
Old 21-01-2012, 09:15 AM   #13
Mechan1k
Mechan1k's Avatar
Get another alignment and report done elsewhere ... and see how it goes.
That's about the only thing I can think of at the moment.
