Closed Thread
Old 16-11-2005, 02:07 PM   #1
ba-xr8
Default Ford or Holden
Hey everyone. before everyone jumps to conclusions i am more interested in peoples opinions. i know this is a Ford forum and all.
recently some of the newer holden clubsport's have caught my eye to the extent that ive almost thought of maybe looking at them instead of an xr8.
is there much of a difference in power between the LS1 and the Boss 260?
the clubsport is a 6 spd manual. its called a hsv clubsport "Y"
apart from the obvious holden vs ford debate would there be any reason why i shouldnt even look at the holdens? are they decent cars compared to the BA xr8?
thanks
ba-xr8 is offline
Old 16-11-2005, 02:14 PM   #2
SunDrifter
To shreads you say?!
SunDrifter's Avatar
I doubt that you'll get a very even answer here. If you must, go test one and see for yourself. But i've said it before and i'll say it again, you can't beat the technical superiority of the XR8's engine/suspension and gearbox when comparing to a commode.
pushrod 2valve per cyclinder 60's tech engine vs 4valve quad over head cams boss engine?
If you want old technology, then shouldn't you also be using a typewriter, not a computer on the internet?
BAII XR6 Ute (manual) Winter white.
Originally Posted by VYBerlinaV8 (LS1.com.au)
I've owned Holdens and Daewoos, and had plenty of problems with Holdens and none with Daewoos. Of course, the Holden is the more desirable car to own and drive, but based on my experience it is not the higher quality of the two.
Originally Posted by SlickHolden
Weight means nothing to a cars handling...
SunDrifter is offline
Old 16-11-2005, 02:20 PM   #3
ba-xr8
ok cool. im not overly technical minded when it comes to cars to be honest. im more curious than anything. thanks
ba-xr8 is offline
Old 16-11-2005, 02:23 PM   #4
Valknutr
Valknutr's Avatar
I test drove a SV6 and an MKII XR6 to help my dad choose a car and we ended up getting the SV6, god damn its a quite car even at Xkm/h....
car that goes (just) <----- gonna be MENACE so :thebirds:
Valknutr is offline
Old 16-11-2005, 02:32 PM   #5
MYVYSS
Back where I belong
MYVYSS's Avatar
And yet compare the Qtr Mile Times and I am sure you will find the HSV is just slightly quicker, also Mods for the LS1 are plentiful, and with minimum spending or modification you could have yourself a 300rwkw machine easily, compared to the Boss which will be expensive and still end up being a slug. They are both nice cars, it will depend upon what you are after, resale you should find that a well maintained HSV will keep its value a little better than your everyday run of the mill XR8, so all in all it should boil down to Personal Choice and style, not so much the same old boring line about Ford/Holden blah blah blah...Sure the XR8 might be a bit better refined, but me personally would go for the true and sheer driving pleasure of a REAL performance vehicle, rather than a PIMPED up Falcon.....(puts on Flame suit about NOW).
Both great cars, take them for an extended Test Drive and see which you feel you would prefer driving on a regular basis....
Regards
Craig
MYVYSS is offline
Old 16-11-2005, 02:32 PM   #6
SunDrifter
SunDrifter's Avatar
Sorry this is O/T but i don't get this. I mean, i drive commodes all the time through work, and even when they are brand new, the V6 commode engine doesn't have a stich on the BA 6cyc. Drive both, they v6 simply does not compare for torque, and grunt. To get anything from the v6 you have to rev this ring out of the poor thing, and heaven help you if you have the dog box automatic behind it.
Old 16-11-2005, 02:36 PM   #7
RED_EL_XR8
RED_EL_XR8's Avatar
For the Mercy of Abraham , why start or contribute in these moronic go nowhere bun fight threads!!
Padlock Please !!!!!
RED_EL_XR8 is offline
Old 16-11-2005, 02:37 PM   #8
MethodX
MethodX's Avatar
Pushrods and OHC were invented around the same time.
MethodX is offline
Old 16-11-2005, 02:38 PM   #9
SSBUB
SSuper SSpy
SSBUB's Avatar
DOHC has been around just as long as the pushrod, so the old vs technology isnt really a debate
Depends what you want out of it...speed = holden, refinement = falcon and both will be argued to the teeth
Test drive both and decide for yourself but keep in mind if you after a fast car its cheap and easy to modify the commodore compared to the Boss...pluss the Boss is heavier...depends on what you like i guess, have a drive of them, and a real spirited drive, not a lap around the block....give them both hell and come back to us :
SSBUB is offline
Old 16-11-2005, 02:39 PM   #10
Sourbastard
Contributing Member
Sourbastard's Avatar
Heh. Not again. Thread Closed.
1965 XP Falcon Deluxe Sedan
1978 XC Falcon Wagon Rallypack
2003 BA Fairlane G220
Windsor Powah!!! http://www.youtube.com/watch?v=m7hT9dxD2hM
Sourbastard is offline
Closed Thread
