31-05-2012, 05:06 PM | #1 | ||
I've had my diesel hatch for nearly 2 mths now and love it. The best car I have owned. It's booked in for 12mth service next week and there's a couple of minor things I want the dealer to look at:
- Exposed steering column just above the brake pedal - is this normal? - Squeaking door rubbers - happens any time I go over something that causes the chassis to flex. In particular when the car has just been washed. - Shuffle songs on the iPod - I like to have shuffle permanently set, but find that I have to re-select shuffle from the menu every time I start the car. I have an iPod connected in the glove box via USB and the audio cables. - Plastic trim around the gear stick lifting - apparently a common problem. Anyone have experience with the above? Thanks in advance. |
04-06-2012, 02:11 PM | #2 | ||
RS shop's technician
-if it's where I think you mean then yes.
- spray the door rubbers with silicon spray after you wash the car this will stop them squeaking -not come across anyone asking me that before -yes is common, needs to be clipped in properly
Advertising removed |
06-06-2012, 01:37 PM | #3 | |||
Good luck |
18-06-2012, 11:40 PM | #4 | ||
Had the service now and thought I would share my learnings:
- Exposed steering column just above the brake pedal - THIS IS NORMAL. - Squeaking door rubbers - FORD RECOMMENDED SILICONE SPRAY, WHICH LASTS FOR A COUPLE OF DAYS BEFORE THE SQUEAKING RETURNS. HOPEFULLY THIS WILL GET BETTER WITH AGE. - Shuffle songs on the iPod - I like to have shuffle permanently set, but find that I have to re-select shuffle from the menu every time I start the car. I have an iPod connected in the glove box via USB and the audio cables. - NO SOLUTION. - Plastic trim around the gear stick lifting - apparently a common problem. - FORD REPLACED THE TRIM UNDER WARRANTY AS ONE OF THE CLIPS WAS BROKEN. |
