Old 03-08-2012, 10:28 PM   #1
2002au
Define definitive
2002au's Avatar
Default Au falcon cruise not working
Hey guys, the cruise control in my s3 xr6 manual doesn't work. It come up with 'cruise' under the odo meter but that's it. Thinking its maybe the brake light switch?
Cheers guys
BF F6 TYPHOON in NEO #718 ~ 356rwkw :
BF XR6 TURBO in SILHOUETTE
2002au is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2012, 10:36 PM   #2
2002au
Define definitive
2002au's Avatar
Default Re: Au falcon cruise not working
Also all the brake lights are working
Old 03-08-2012, 10:39 PM   #3
FOCUSonTHIS
FOCUSonTHIS's Avatar
Could be the the cruise buttons on the steering wheel
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 03-08-2012, 11:09 PM   #4
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
Check your horn Cassidy... Could simply be dodgy switches, or a broken clock spring.
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2012, 07:37 AM   #5
Sox
RIP...
Sox's Avatar
The clutch pedal may also be slightly down, resting on the switch.
Oval Everywhere...
Old 04-08-2012, 12:44 PM   #6
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For the effort put into the Australia day cruise to Albury Tech Writer: Recognition for the technical writers of AFF - Issue reason: AU Tech article.
There is a failsafe switch attached to the brake booster master cylinder (the only wires on the MC). I have had to replace this in the past as it stops the cruise from engaging. Pretty cheap to replace too if I remember correctly.
Good luck with it.
Stu
2002 AU II LTD
5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust.
Quarter Mile: 13.73 @ 105.86mph
Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024
2002 XR8 pursuit 250
Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
auIILTD is online now   Reply With Quote Multi-Quote with this Post
Old 04-08-2012, 06:12 PM   #7
2002au
Define definitive
2002au's Avatar
Ok cheers guys
Might sound stupid but is there anyway it check the cruise buttons on the wheel?
Also the horn works fine..
Old 04-08-2012, 07:00 PM   #8
FOCUSonTHIS
Originally Posted by 2002au
Ok cheers guys
Horn runs on a separate wire that connects to the airbag.
Only way to check if the buttons work is to take the airbag off. You will need the anti theft t-bits to remove the airbag. Then remove switches and check with a multi-meter.
That is my assumption, I am not the best with electrical
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 04-08-2012, 07:36 PM   #9
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
No need to go though all that. Look at the wiring diagrams on this site and measure at the connector that runs down the steering column.
2002 AU II LTD
Old 05-08-2012, 08:03 AM   #10
The Monty
Just slidin'
The Monty's Avatar
Id seriously just check your brake lights first, all three of them.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 05-08-2012, 09:12 AM   #11
GK
Walking with God
GK's Avatar
+1
Exactly what you've described was caused by blown brake lights in my sedan.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 05-08-2012, 10:49 AM   #12
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
He's done this fellas.
2002 AU II LTD
Old 05-08-2012, 11:10 AM   #13
The Monty
Just slidin'
The Monty's Avatar
Obviously paying more attention then what I am, lol. Sorry bout that.
Old 05-08-2012, 12:00 PM   #14
rmack
rmack's Avatar
You can bypass the booster switch for testing by unplugging and inserting a wire link into the plug. (NOT THE BOOSTER SIDE).
BUILD AU II FAIRMONT GHIA
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
rmack is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2012, 08:42 PM   #15
Gaz
Got Ghia?
Gaz's Avatar
The horn buttons earth through the cruise module.
You've said the word cruise comes up, so the module is alive.
The horn buttons earth through the CC, but they also use the same earth in the clock spring. The volume buttons also use that earth, so if they work, the return wiring is definitely fine. The cruise buttons do have their own feed through the clock spring though.
I'd check the buttons/wiring for a voltage spike at the CC module across the Orange(Yellow trace) wire and earth, when someone presses either Set + or Set -. It will just be quick spike, and will be different for + and - buttons.
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold
2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers
Gaz is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2012, 12:10 AM   #16
Gaz
Got Ghia?
Gaz's Avatar
Seeing I can't edit that post. The above is slightly wrong.
You need to measure across the Orange-yellow wire and the black* wire.
*There seems to be 2 black wires on the cruise module plug, one goes to earth from the module, the other into the module from the buttons. I haven't checked their location on the plug, but one should show 12v between the orange and it with the cruise on ("Cruise" on the dash), the other should show 0v. That's the one you want. Press a set button and see if you see the voltage move.
Hope I got it right this time
